Hi first post . need help
  • zim6000
  • zim6000's Avatar Topic Author
22 Apr 2007 09:54
#132739
I'm working on a crashed kz750 spectre its a 1983 model
and I need the pulsing coil and advancer and the bolt that holds it on they were all crushed in the wreck.
anyway the question is will a coil and advancer from a 81 model work if not does anyone know where I can find the parts?
any help would be greatly welcomed :)
  • OKC_Kent
  • OKC_Kent's Avatar
Re: Hi first post . need help
22 Apr 2007 10:20
#132751
I have the impression that those parts are the same for all the small four cylinders, 550-650-750, that use electronic ignition. The advancer weights may be different tho, to control the advance. but I think if you stay with a 750 you are good to go.
On my '83 750 LTD shaft, (Same as your Spectre, basically) I am rebuilding the same things from a crash. I grabbed a 750 advancer off ebay, and the pulsing coils too. I didn't really pay attention to what year it was, it should work.
On my 650 I am using 550 pulsing coils and a 750 advancer cam/lobe on the original 650 advancer. The 650 runs smooth now.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • loudhvx
  • loudhvx's Avatar
22 Apr 2007 10:32
#132754
For the 550/650/700/750 4-cyl, there are two types of electronic ignition. One is a mechanical-advance type, andthe other is electronic advance. The parts don't interchange between the two systems. The 83 Spectre uses the mechanical-advance type.
The electronic advance type system can't be installed (without modification) on (some or all?) of the older engines due to a clearance problem in the motor casting.
However, the older type can usualy fit into a newer engine. Normally you wouldn't do that unless you were short on cash or time, or something.
  • zim6000
22 Apr 2007 16:11
#132829
Thanks for the replies the parts I'm biding on ebay right now don't match the broke parts I have 100 percent
but they look close the only diferince I can see is on the coil the magnets or what I think are magnets are covered in plastic the advancer looks just like the one I have.
sorry if thats not a very clear description
whats too much to pay for these parts and would the dealer have them?
