wiring harness swap
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
wiring harness swap
19 Apr 2007 14:58
#131963
i finally gave up on trying to repair my "modified wiring harness", done by the previous owner. I was able to track down a wiring harness for a 78 kz 650c, my question is will this work on my bike, its a 77 kz 650b, im also reblacing the handle bar electrical switches. does anybody know if this is going to work or am i just wasting my time, or should i try to find a wiring harness from a 77 kz 650. thanks
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
Re: wiring harness swap
19 Apr 2007 15:11
#131970
The only thing I can think of that would differ between the two is that the 650 C came with 4 way flashers and I don't think the B models had them. Other than that it should be a pretty straightforward swap.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • reborn650
  • reborn650's Avatar
19 Apr 2007 16:52
#131999
Hey oldkaws4ever - Nice user name by the way.
The gringo is correct, the only electrical difference between the B and C is the 4 way flashers found on the Custom.
My advice to you is to take lots of picture...lots, to make sure that you know how every wire feeds through the frame and exactly what goes where. One simple misplaced wire and you could be hunting down and electrical gremlin for a long long time.
-1998 Jeep TJ Wrangler 4.0...
  • oldkaws4ever
19 Apr 2007 21:08
#132080
thanks alot gringo and reborn 650, i'll make sure to take lots of pics of the harness
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • loudhvx
  • loudhvx's Avatar
19 Apr 2007 22:20
#132115
The charging systems are totally different. There have been a few threads on this issue lately so a search may help.
The 77 650 uses a 3-phase, excited-field alternator, and seperate regulator and rectifier. The 78 650 uses a 1-phase, permanent-magnet alternator, and a combined reg/rec.
You will have to add several wires to the 78 harness.
