halogen headlight
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
halogen headlight
17 Apr 2007 22:06
#131387
i just bought a halogen headlight to replace the stock one on the Z1 900, can i just plug it in, or do i have to run an inline fuse somewere?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • AR15Ron
  • AR15Ron's Avatar
Re: halogen headlight
17 Apr 2007 22:11
#131388
The one I just bought plugged right in. There was some discussion as to the stock wiring being heavy enough for the added current draw but so far it seems fine.
  • BSKZ650
  • BSKZ650's Avatar
18 Apr 2007 05:38
#131450
been running one of those brite white bulbs in mine for quite some time, my only worry is that it cant take the extra vibration that a bike has
77 ltd1000, current rider
76 kz900, just waiting
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
18 Apr 2007 08:07
#131489
As long as You're not using a high wattage bulb(95/100) and stick to the normal(legal)H-4 55/60...You should have no problems.:whistle:
1977 KZ1000 A-1
  • OKC_Kent
  • OKC_Kent's Avatar
18 Apr 2007 08:25
#131492
I use the 55/60w H4 bulbs, and there are different numbers than H4 that use the same 3 blade connector, like maybe 9003 or 9004?? Plus add the Xenon and other gases and there are a few of them.
What I have found is that the 9003/4 and other fancy bulbs don't last as long as a real H4 bulb, which is made (and labeled) for offroad use and handles the vibes better on a bike.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • old650
  • old650's Avatar
18 Apr 2007 09:11
#131507
Interesting. Maybe I'll be a little more selective next time, after seeing this info. Twice in the past I put in off the shelf Halogens from auto stores and they both died an early death. One just lost highbeam and the other was totally roasted. Actually I'm sure that I tried to get similar current draw on at least one, dunno, can't remember. Anyway, I dought that I got more than a month out of either with my 650. But man when they work, what a difference !
