Aftermarket turn signals.
- tnutz
14 Apr 2007 20:29
I want to run after market signals on my 81 GPZ 1100, but the ones i want have a 6watt halogen bulb. To make these work correctly i can just add a Resistor in series with it correct?
Kellermann
Turn Signals
Micro 1000
www.whaccessories.com/Turn%20Signals.htm
Kellermann
Turn Signals
Micro 1000
- Biquetoast
- King Jeremy The Wicked
Re: Aftermarket turn signals.
15 Apr 2007 05:54
tnutz wrote:
I don't know much about electronics, but isn't it the case that these will use less power? If so, why not just use a "heavy-duty" or "electronic" turn signal blinker? That's what I did when I switched to LEDs, and I got my replacement blinker unit from AutoZone for like $7... It perfectly regulated the blinking no matter how much power is drawn......To make these work correctly i can just add a Resistor in series with it correct?...
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- tnutz
