Rectifier heat?
- BARNEYHYPHEN
Rectifier heat?
13 Apr 2007 14:47
1976 kz900. Should the rectifier be too hot to leave your finger on more than a second or so?
I had a fuse blowing problem last week, when gunning hard up to about 6,500 to pass a line of cars. Happened 3 times. Found what I thought might be a short and corrected it but noticed in passing that the rectifier was real hot.
Haven't tried the gunning test again yet. just thought I'd ask the recifier question first. Thanks.
- The Milkman
Re: Rectifier heat?
13 Apr 2007 14:52
Yes, Barney it gets pretty hot because any power that the battery or accessories isn't using from it is directed to ground which can cause quite a lot of heat build up. It doesn't hurt to take it off once in a while and clean the contact areas on the frame where it mounts to give it better heat transfer to the fram.
Ride safe,
Les
Ride safe,
Les
- BARNEYHYPHEN
Re: Rectifier heat?
13 Apr 2007 15:09
Thanks Milkman.
I've actually just recently rebuilt/soldered all the joints and totally cleaned the whole four plug/rectifier/solenoid set-up so that whole mess of wires is now VERY clean & totally tidied-up.
At the same time, I fitted a "new" (cleaner than my old one) rectifier. Just never thought about or noticed the old one getting that hot.
