LED brake light, blinking brake indicator
- AR15Ron
13 Apr 2007 09:39
Has anyone else had this problem? Everything WORKS but when I turn the lights on the brake light indicator blinks like it does when the brake light is not plugged in. It all works just fine but the blinking light is a little annoying. If I dont turn the head light on then it does not blink and still lights up when the brakes are applied. Seems kind of odd. I'm wondering if I need more resistance on the parking light circuit to make it stop.
Ron
Ron
- Biquetoast
- King Jeremy The Wicked
Re: LED brake light, blinking brake indicator
13 Apr 2007 09:43
AR15Ron wrote:
There is a natual resistance in the regular light, and that's how the brake light "failure indicator" (the blinking light) works. If it detects a very low draw, like an LED or a burned out regular bulb, it thinks that the bulb is burned out.
I actuall solved it by putting *just enough* LEDs on the circuit to cause it to detect the draw. I added a license plate rind with another LED on it and it solved my problem.
Now, I know nothing about electronics, so I don't even know what that means, I just know it worked...
Other people have added resistors or whatever, others have removed the failure indicator, others have removed the bulb from the dash...
Good luck!
It's a very common problem that has come up often.Has anyone else had this problem? ...
Good luck!
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- AR15Ron
14 Apr 2007 02:11
That's pretty much what I was thinking. I'm gonna try and find some more LED's to plug in. Seems like a waste to use a resistor. I like the indicator that tells me the brake light is on so I'd like to keep it working. It's kind of funny that the brake light doesnt make it flash only the parking lights. Think I'll go check ebay for a license plate frame or something
I like that idea.
Ron
Ron
- Biquetoast
14 Apr 2007 05:42
AR15Ron wrote:
It just *happened* to work for me, I cannot say why...
And I don't know if it matters, but the LED taillight I'm using is the Radiantz 1.85" Direct Base LED cluster from Custom Dynamics, with this license plate ring LED:
Post edited by: Biquetoast, at: 2007/04/14 08:42
No guarantees, no promises......Think I'll go check ebay for a license plate frame or somethingI like that idea....
kz750twins.com
kz750twins.com
- shaftie1100
17 Apr 2007 14:48
You need to add resistance to the line!!! Search online, this is a common function of Ohm's law. Assuming you can do some light soldering; if you supply me with the stats of your new blinkers I can try to help you out...
- AR15Ron
17 Apr 2007 22:01
I just don't want to add resistance when I can just add lights instead
Resistance = heat = a waste of electricty
- shaftie1100
18 Apr 2007 08:26
I can't and/or won't argue taste! Yes, adding LEDs to the circuit would increase the resistance on the line... IMO, I wouldn't drive a Christmas tree...
