Tach/voltmeter not working
- pyxen
13 Apr 2007 07:21
So I've got everything done that I really want to do..except tighten up the clutch, but that'll be another thread..AND the tach isn't working.
I've tested the connectors, and it seems that something's going on in there.. I get some wierd negative reading on my digital multimeter when I touch the connector. The other ones give me a decent 12v or so.. Everything is connected to the coils (electric tach), so that's fine (I think).
The service manual is so light on what to do here, that I'm kinda at a loss.. anyone have any advice?
I'd like to have my tach back.. :pinch: At least I have a working speedo now though! :laugh:
On second thought.. I've attached the voltmeter switch to the metal bracket between the gauges - would that cause it to stop working? I don't think I insulated it.. It was originally installed in a plastic housing. Hrm.. guess I'd better check that, eh?
Post edited by: pyxen, at: 2007/04/13 10:24
84 KZ550-F2 LTD
93 ZR550-B4
93 ZR550-B4
- kzwolfsr
Re: Tach/voltmeter not working
14 Apr 2007 19:51
Geez Pyxen, I have the opposite problem. My speedo don't work. I got a speeding ticket for it the other day but that was dismissed but I still have to pay a fine for defective equipment... broken speedo which I told the cop about.... dumb butt I was. I guessed it was the orange wire but it wasnt that. I will go through my prob probably tomorow and see how I can help you. Ticket on my 1000, sorry for lack of info.
Original man of the Caribbean
- pyxen
16 Apr 2007 10:37
Awesome.. I've got the backing plate off my gauge, and I'm going to dig in there with my tester again to see if I can figure out whether or not there is indeed a signal coming from the engine.
Everything is hooked up properly, afaik, so I don't understand what the deal is.. It was working perfectly last fall. As if that means anything! :lol:
84 KZ550-F2 LTD
93 ZR550-B4
93 ZR550-B4
- pyxen
17 Apr 2007 14:27
Okay - I've done my checking and definitely need some help..
When the bike is on, but not running, the multimeter registers around 4 volts - when it should be 0. With the bike running, it's registering around 1 volt, when it should be between 2 and 4..!
WTF?? The manual says that the wiring between the coils and gauge is to blame, so does this mean all I need to do is run some new wire? This kinda sucks.
Are there any other tests I can do..can I clean something and make it go away?
Does it matter which side of the coil the power and negative leads go on? Could that be the problem?
Right now I have the red/yellow going to the left (from the top) connectors on both coils, and the green or two black (which is, I assume, where the signal to the tach comes from) on the right connectors.
Oye..help please!
Oye..help please!
84 KZ550-F2 LTD
93 ZR550-B4
93 ZR550-B4
- pyxen
18 Apr 2007 13:36
Aight.. I nailed it down. It's a sticky/busted voltmeter switch that was messing things up..now that I've 'twiddled' it a bit, the tach works fine..its just the voltmeter itself that doesn't seem to work
84 KZ550-F2 LTD
93 ZR550-B4
93 ZR550-B4
- kzwolfsr
18 Apr 2007 18:28
Sorry man1 Didn't get to fool with mine.
