starters!!!!!
  • senese100
  • senese100's Avatar Topic Author
starters!!!!!
09 Apr 2007 22:50
#128378
please help me I have a 1982 kz 750 ltd that has a starter problem it doesnt always engage!after a couple of turnovers it will start up!however I also have a 1982 kz 550 gpz can I switch the starters?Will they bolt up? are they different? and has anybody done it?
  • wiredgeorge
  • wiredgeorge's Avatar
Re: starters!!!!!
10 Apr 2007 06:15
#128437
Many starters from various Japanese bikes will cross fit different models. Go to www.kawasaki.com and look up the parts diagram for the bikes these starters came from under "owner info" and check part numbers.
You may not have a bad starter anyway. If it works some times but not everytime, it could be the clutch of the wrong shims under the cogged wheel that drives the starter.
Post edited by: wiredgeorge, at: 2007/04/10 09:16
  • loudhvx
  • loudhvx's Avatar
Re: starters!!!!!
10 Apr 2007 08:16
#128481
550 starter is smaller
  • senese100
Re: starters!!!!!
10 Apr 2007 10:13
#128520
thanks guys for helping me out however if you have alot of gpz's I might be interested if you intend to part some bikes out!!!
  • wiredgeorge
Re: starters!!!!!
10 Apr 2007 16:36
#128614
If you actually go to kawasaki.com and get the part number for your bike, you can plug it into the part number search and it will tell you all the models that used the same starter.
  • senese100
Re: starters!!!!!
10 Apr 2007 17:12
#128622
oh ok thanks alot!,Matt
