Dim alternator light??
  • spectrerob
  • spectrerob's Avatar Topic Author
07 Apr 2007 17:58
#127512
1982 KZ1100 D1 Spectre
I didn't notice the alternator light coming on until I road at night. It is on steady but very dim. Does this indicate any problem? A friend sugessted a bad regulator.
Great forum. Thanks for any help.
  • kawsakiman
  • kawsakiman's Avatar
Re: Dim alternator light??
07 Apr 2007 20:02
#127553
listen to your friend
  • loudhvx
  • loudhvx's Avatar
07 Apr 2007 23:15
#127605
The regulator is a voltage regulator. To verify that it is working, just measure the voltage on the battery. If the battery voltage increases to about 14~14.5v as you rev the engine to 4000 RPM steady, and doesn't go higher than 14.5 then the regulator is working (along with the rest of the charging system). In that case, perhaps the light is malfunctioning.
If you get more than 15v, then the regulator is bad or not connected properly. If it never gets above 13v, then it can be one or more problems with any part of the charging system.
Also, are you sure it's an alternator light? I'm not familiar with that system so I can't say what the alternator light is actually indicating. I know some KZ's had an electrolyte sensor in the battery, but that just detects water in the battery.
