IF
  • customkzft
  • customkzft's Avatar Topic Author
IF
04 Apr 2007 18:29
#126517
If the possitive wire going to the coil is getting juice but there is no spark from the wires, plugs it means the coils is bad right?
  • loudhvx
  • loudhvx's Avatar
Re: IF
04 Apr 2007 23:50
#126614
Not necessarily. There needs to be a lot more info to come to any conclusion.
What bike? Points, or electronic? What ignition? How many coils? How much juice? How many ignition interlocks? Yada yada yada...
  • apeman
  • apeman's Avatar
Re: IF
05 Apr 2007 00:10
#126617
You can have full power to the coil positive terminal, but it will not work if the ground terminal wire does not fully complete the circuit. Check your ground connector resistance (against the engine case metal). If it shows anything other than near 0 ohms, you have a ground problem.
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
  • AR15Ron
  • AR15Ron's Avatar
Re: IF
05 Apr 2007 03:20
#126626
Also if the set of points (assuming you have points) is not functioning that are attached to that coil, no sparky. Read this thread, might have some relevance.
Linky to thread
