KZ starter relay
  • bbene609
  • bbene609's Avatar Topic Author
KZ starter relay
04 Apr 2007 05:49
#126352
Does anyone know if a 1981 kz550 starter solenoid is the same as the solenoid for the 1981 kz750????
Thanks
bbene
  • kzwolfsr
  • kzwolfsr's Avatar
Re: KZ starter relay
04 Apr 2007 06:28
#126363
Possible interchangable. Check parts diagrams on kawasaki.com
Original man of the Caribbean
  • wiredgeorge
  • wiredgeorge's Avatar
04 Apr 2007 06:45
#126371
A starter relay is a starter relay. The main issue with using the relay from one bike model on another is the mounting and not the basic function... a wire goes to battery. A wire go to starter. A wire comes in from start button. There may or may not be a ground wire... Kaw likes to use ground wires and Suzuki doesn't. If you need a ground, you can use a mount bolt.
  • bbene609
05 Apr 2007 06:53
#126658
Thanks KZWOLF. Exactly what i needed.
Thanks WIREDGEORGE. I knew about the solenoid but i needed the same one for color coding of the wires and i didn't want to cut and splice new connectors.
  • wiredgeorge
06 Apr 2007 05:09
#126967
Color coding for the solenoid? There really is none. The solenoid only may have a ground wire which will be either black or black/yellow on any solenoid, regardless of what make/model it is used for. The solenoid will have a lug for connecting a trigger wire. On a Kaw, this is always a black wire coming from the starter button. There will also be two large lugs for connecting the starter cable on one and connecting the battery cable and cable coming from the reg/rec...
