brake lights
  • squints
  • squints's Avatar Topic Author
brake lights
03 Apr 2007 07:15
#126089
my running light is working but the brake light isn't working when I engage the brakes. I dont know electricals, any help on where to start? could it be as simple as a bulb?
traded my classic Kz's for a 2001 Kz1200r
Upstate NY
  • ltdrider
  • ltdrider's Avatar
Re: brake lights
03 Apr 2007 07:22
#126094
If your tail light works, but your brake light doesn't come one - when you apply the front or back brakes - then it's probably just the bulb. The tail bulb has two elements, a dim one for the tail light, and a bright one for the brake light. Your bright element might be shot. You should be able to see the burnout if you take off the red lens and look at the bulb.
If you can get the brake light to come on with either the front or back brake applied, then it's probably a switch or a wiring connection.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
  • KaZooCruiser
  • KaZooCruiser's Avatar
Re: brake lights
03 Apr 2007 09:28
#126159
squints wrote:
. . . could it be as simple as a bulb?
yes
  • squints
Re: brake lights
03 Apr 2007 12:59
#126202
Awesome, thats what I thought too becuase the light was on, just no flashy flashy when I brakey brakey.
Since I'm not near my bike right now, any chance someone knows the part number for that bulb???
Upstate NY
  • KaZooCruiser
Re: brake lights
03 Apr 2007 13:39
#126210
If it's a two-filiment, offset bayonet base, it's probably an 1157.
I'm not near your bike either.
You are going to have to remove the lens to remove the bulb When you take out the bulb, push in a little on it, and then turn it counterclockwise a little and it should come out. Take it with you to the auto parts store, so you can match it up. I think there is a 1157LL bulb which is new technology and may last longer and burn brighter than the older 1157.
Don't force the new bulb in. It has an offset base, so it is only supposed to install one way.
You might wear gloves while changing the bulb. It could be that the old one is stuck and if the glass breaks while you are fooling with it, the gloves might protect you. Don't want you to get bit by your bike while you are playing with it's @$$. That kind of thing can ruin a day.
  • AR15Ron
  • AR15Ron's Avatar
Re: brake lights
03 Apr 2007 22:01
#126317
there is an 1157LL, worth the extra $1 or so. Long life, think its brighter too. When you change the blub it doesnt hurt to put a little contact grease on it so it wont get stuck in there for the next time. Mine was rusted in pretty good, gloves = good idea. Your local auto parts store should be able to hook you up. Any doubt bring the old bulb with you.
Ron
  • BSKZ650
  • BSKZ650's Avatar
Re: brake lights
04 Apr 2007 05:34
#126350
I just put one of the LED bulbs, in my 1000, still not sure if its better or not, but it may last longer
77 ltd1000, current rider
76 kz900, just waiting
  • pyxen
  • pyxen's Avatar
Re: brake lights
04 Apr 2007 05:40
#126351
I had trouble with 1157 style LED blubs.. I couldn't get the tail lights to come on, but the brakes worked. Not sure what the deal on that one was, but I've still got my standard bulbs in there.
I'd love to have the LEDs in there though, cause it's a much nicer red, though I don't think it's any brighter.
I haven't fooled around with it too much yet - so I'm obviously not *that* hard up to get it to work.
84 KZ550-F2 LTD
93 ZR550-B4
