two questions? dry battery/battery eliminator
- dnestell
- loudhvx
- Thank you received: 1615
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- dnestell
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- Corith
- dnestell
Post edited by: dnestell, at: 2007/04/02 14:32
- Corith
I knew SOMEONE would ask me what size capacitor I have. The bike is in storage for the winter a good hour away from where I live. I recently got an email from the website I ordered it from that it is now obsolete. But here is the info on the capacitor...
Discontinued Item:
Manufacturer Name: CDE MALLORY
Manufacturer Part Number: CGS562U075R4C
Manufacturer Discontinued Date: 02/01/06
Newark InOne Sku: 07C9742
Last Time You Purchased this item: 05/02/05
Product Description: Aluminum Electrolytic Capacitor Capacitance:5.6mF;
Capacitance Tolerance:+75, -10 %; Working Voltage, DC:75V; Terminal
Type: Screw; Series: CGS; Features:Computer-Grade
Loud will probably have something to say about this. My bike starts up VERY well off one kick, so if Loud could give you some advice on a bigger capacitor, that might work best. I turn off my headlights when I kick it, but at idle it can run my headlight, my running lights (my turn signals are dual filament bulbs, and also serve as running lights), any two blinkers or all four for hazards.
I don't think I tested trying the horn under load. Like I said, my worry was getting TOO big of a capacitor and it not being able to charge in one kick. Since it seems to startup okay, I would suggest trying to goto a little bit bigger of a capacitor. I think I'm on the line as for how much load I need and can use.
-- Craig
Post edited by: Corith, at: 2007/04/02 14:48
- dnestell
- loudhvx
(Watch out for confusion because sometimes people use mF to mean micro-farad, but that would be improper. The abbreviation for micro-farad is uF, where the u is a actuallly a substitute for the greek letter "mu" which actually looks like a cross between a "u" and an "m". Confusing enough yet? )
You'll want the cap rated for around 50v (higher is better, but 50v should be fine).
The issue of charging the cap in one kick is a concern. Since the stock 650 with points only uses one coil at a time, it uses about half the current as the Dyna S. The Dyna S has both coils on almost all the time. Try it and see is probably the best way to find out.
If the bike is hard to get started with a good battery (kickstart, that is), it'll only be harder to start with a capacitor.
If it starts in one kick pretty reliably, then the capacitor has a good chance of working.
By the way, for anyone else reading, the battery eliminator is not eligible on a 77 650 with stock charging system. That bike needs a battery (however, it can be very small).
Post edited by: loudhvx, at: 2007/04/03 02:11
1981 KZ550 D1 gpz.
Other links.
- dnestell
- loudhvx
Generally speaking, on the 650 and 400 KZs, the way to tell is to look at the alternator cover. Notice on the 77 650 and the 76 400 that there are three screws in a triangle shape in the center of the cover. That means it needs a battery to work.
If there are no screws in the center of the cover, you can get away with a capacitor.
1981 KZ550 D1 gpz.
Other links.
- dnestell
