Dim turn signals
- DeadHeadSurfer
Dim turn signals
10 Dec 2005 16:19
Hi,
I have a 1979 KZ650SR. I recently got it back from the mechanic, who cleaned and tuned my carbs. Now I am moving on to all the other little bits that need attention. I have noticed that my turn signals have suddenly dimmed significantly, as in almost impossible to see. They used to work well, and were quite bright. I suspect this is probably due to a bad connection somewhere, but which areas should I check first? This is affecting all four signals, and the actual blinking lights on the gauges as well.
Also, soon I will be getting new tires. Any recommendations? I am considering the Dunlop GT501's, but if people have had success with the D404's, I might go with those to save a few bucks. I don't want to go cheap though, and the GT501's look like a nice tire.
Looks like I will be bleeding the brakes soon too. I would just feel more comfortable knowing I have fresh clean fluid. I'm guessing this is a fairly simple procedure? or are there any tricks/tips to it?
Thanks,
Jason
Post edited by: DeadHeadSurfer, at: 2005/12/10 19:20
Thanks,
Jason
- RomSpaceKnight
Re: Dim turn signals
11 Dec 2005 06:02
Look for a bad ground (my first guess) or faulty turn signal relay.
- rstnick
11 Dec 2005 06:19
Welcome to KZR DHS.
Check your battery for strength, if it doesn't have a full charge, you will have weak lights. You may need a new battery if it's very old.
Here's a post on brake bleeding that has some good info: Brake bleeding . Search in the archives for more info.
And then there's the Tire Poll .
Gives us some pictures of your ride as well.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- DeadHeadSurfer
13 Dec 2005 13:32
Hi,
Thanks for the advice. I got the signals working, but I think I have a faulty hazard relay. Let the hunt begin...
It looks like the GT501's are the way to go, so I'll get those ordered soon.
Here's a pic
Here's a pic
- DeadHeadSurfer
