new dyna coils
  • oldkaws4ever
  • oldkaws4ever's Avatar Topic Author
  • Have no regrets...... You only live once.
new dyna coils
30 Mar 2007 17:37
#125036
the coils just died in the z1, so i ordered 3.0 ohm dyna coils and dyna wires. im still running points but im going to put in the electronc ignition oneday. how do the dyna coils plug into the wiring ( the 2 male and female connectors on each coil)? 3.0 ohm coils are ok for a 74 z1 900 right?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • ltdrider
  • ltdrider's Avatar
Re: new dyna coils
30 Mar 2007 17:51
#125038
You will get a wiring diagram with the coils. The dyna setup uses a funky bayonette crimp for the power (I think) wire. You really should put a decent connector or solder that connection.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
  • Bluemeanie
  • Bluemeanie's Avatar
Re: new dyna coils
30 Mar 2007 18:13
#125044
Listen to ltdrider, throw away the blue (Dyna S right?) connector and solder the connection! I used that connector and started randomly dropping cylinders on and off. Drve me nuts trying to figure that out. Wiredgeorge came to the rescue! Have not had a single problem since.
