Coil Powering
  • 77_650B1
  • 77_650B1's Avatar Topic Author
Coil Powering
14 Mar 2007 15:49
#120198
For a bit of background, my bikes been having a bit of trouble, I'm trying to get her ready for summer. I cleaned the carbs the other day and put thenm back on tonight.
Anyhow, she'd running crappily. one cylinder is firing hard, one not at all, and the other two are puffing smoke. And the one that isn't working switched from 1 last week to 2 tonight. So I think it must be power to my coils or a related issue. I've got a dyna-s and i wired up my coils like wiredgeorge says.
My only question other than a general plea for help is, could it be that my coils arent getting the proper power from the alternator because the battery is low? Bike's been sitting for three months.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
  • 77_650B1
Re: Coil Powering
14 Mar 2007 17:10
#120220
Update: I'm losing 2V between my battery and coil terminals. I guess i have to take care of that before i start anythign else.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
  • Bluemeanie
  • Bluemeanie's Avatar
Re: Coil Powering
15 Mar 2007 05:48
#120325
Make sure you have a fully charged battery as WG's coil mod is designed to provide a full 12 volts if done properly, check WG' wiring diagram and make sure you did it right... :)
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
Re: Coil Powering
15 Mar 2007 06:20
#120333
Anyhow, she'd running crappily...
I'm curious - why don't you suspect your carbs if that's the only thing that has changed? Like for instance, when you cleaned them (and you didn't mention *how*), could you have dislodged some debris that is now clogging somewhere? How about float settings? Could they have been accidentally bumped? Did you re-balance the carbs after mounting them? Are you sure they are fully seated in the manifolds? You can see where I'm going with this... hope it helps...
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • 77_650B1
Re: Coil Powering
16 Mar 2007 18:45
#120854
Oh, the carb cleaning never changed a thing, i just sprayed some stuff in the bottom end of them and blew everything out with compressed air, and repeat.
I really think its ignition related.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
  • Bluemeanie
Re: Coil Powering
17 Mar 2007 05:37
#120957
Exactly when did the problem start? Was it after the carb work?, the dyna s?, or the coil mod? That can tell where the problem is. If you just put in the dyna s, throw away the blue connector supplied in the kit and solder that connection (trust me), then recheck your coil mod wiring, let us know...
