electrical problem believed to be in handlebars
  • barksdaleammo
  • barksdaleammo's Avatar Topic Author
06 Mar 2007 09:29
#117732
i wish i could get it fixed before i leave. does anyone have a clue as to what to fix? It has a new stator on it and a new battery. ever since i replaced the clutch cable on the handle bar it starts weriod. like the battery has no power. could i have pinched something and made it have a constant power on all the time that could be draining battery power. I also thought it was the regulator/rectifier. any help would be appreciated.
  • riverroad
  • riverroad's Avatar
  • 1980 1000LTD B4
Re: electrical problem believed to be in handlebars
06 Mar 2007 10:45
#117759
I'm not familiar with your engine, but I'm having hard time imagining how a clutch cable could interfere with your starter circuit.
Does the bike start at all? Or does it just crank real slow and not fire?
Is it possible the stator you installed is bad, and your new battery happened to drain down about the same time you changed the clutch cable?
  • pyxen
  • pyxen's Avatar
06 Mar 2007 11:01
#117763
Could you have disconnected/cut something when routing the cable near the coils?
84 KZ550-F2 LTD
93 ZR550-B4
  • OKC_Kent
  • OKC_Kent's Avatar
06 Mar 2007 11:20
#117771
Hi barksdaleammo,
When you replaced the clutch cable did you jiggle loose the safety starter switch wiring? It's on the left clutch perch below the lever, but this is just a guess; my bike has one, but I don't know what bike you have because you didn't tell us.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • KaZooCruiser
  • KaZooCruiser's Avatar
06 Mar 2007 11:41
#117779
Bike posting started here. . .
kzrider.com/component/option,com_joomlab...,9/id,117551/#117757
Helps to have machine details in the signature line, not always obvious to new users. . .
:whistle:
  • barksdaleammo
06 Mar 2007 13:28
#117813
so sorry guys. its a 1984 zn1100 LTD B-1. I dont think the stator was bad. im just lost on the whole issue. sometimes when i start it its feels slow to start but other times its like its dead as a door nail.
  • barksdaleammo
06 Mar 2007 15:53
#117852
anymore takers on how to fix it.
06 Mar 2007 17:09
#117862
Here's some wild speculation based on Honda GB500 safety switches for clutch and sidestand operations. Prevents starter engagement with kickstand deployed if transmission's not in neutral. Also kills ignition if kickstand deployed while transmission's not in neutral. Prevents unexpectedly lurching forward when attempting to crank the engine. And prevents operation of the motorcycle with the kickstand down.
Being unfamiliar with the clutch switch shown in the parts diagram for 1984 ZN1100-B1, am guessing the clutch switch may prevent the starter from engaging with transmission in gear unless the clutch is disengaged (i.e., clutch lever is squeezed in) -- all to prevent the bike from unexpectedly lurching forward when attempting to crank the engine.
Anyway, might attempt cranking while sitting on the bike with sidestand up and clutch lever squeezed in to the handlebar and transmission in neutral. Ignition on. Kill switch off. What happens then?
Post edited by: Patton, at: 2007/03/06 20:11
  • barksdaleammo
06 Mar 2007 17:16
#117864
I tried holding in the clutch and having the kickstand up but nothing. i really think i have a constant power on the battery somehow. i dont know. all i know is stuff about cars.
06 Mar 2007 17:48
#117870
Here's a quickie test for battery current drain with everything supposedly turned off. Disconnect negative cable from negative battery post. Charge battery. Touch negative cable end to negative battery post (tap-tap-tap). Should not be any spark. If there's sparking with everything turned off, something is drawing power from the battery. If there's no sparking and the battery simply won't hold a charge (even with the negative post disconnected), probably just a bad battery.
An amp meter may be connected between the negative cable end and negative battery post to show the amount of current drain involved (which causes the sparking mentioned above).
  • wiredgeorge
  • wiredgeorge's Avatar
07 Mar 2007 06:25
#118022
Airman! Go into your profile and edit it to include bike year/model and your location! (hehe - I used to be a buck Sgt in the Army about almost 35 years ago so consider the order a request from a moderator).
OK, FIRST PROBLEM... What the heck is the problem? Your description has led to what I suspect are "rabbit trails"... info leading down blind alleys.
The bike turns over some times and doesn't turn over at other? Is this the issue?
First, test the starter. There are TWO lugs on the starter solenoid. Take a piece of 14 ga. or thicker wire and touch the POSITIVE battery terminal with one end. Touch the other end to the lug on the solenoid where the starter cable is connected. It is a thick and black shielded cable... Looks like a 6 ga. cable. If the starter spins nicely (put on centerstand and in neutral while you do this), the starter is OK.
Next, test the starter solenoid if the starter proved OK... Look at the solenoid. There are two big lugs on the solenoid. One had the starter cable and the other doesn't. Ignore these. There is yet another connection. This connection has a black wire soldered to it. This is the one we want. Take the 14 ga. wire length you used in the previous test. Touch one end on the POSITIVE battery terminal and touch the other end on the place where the black wire is soldered. Does the starter turn over as it should? If no, the starter solenoid is the problem. If it turns over OK... the problem is in the wiring that gets the trigger voltage TO the solenoid. The trigger is that little black wire that is soldered on the solenoid.
OK, to get that trigger power to the solenoid to trigger it, here is what happens... power comes from your stator, it turned to DC and made the right voltage by the reg/rec and then goes to your battery and the main fuse as it comes out the reg/rec. It then goes to your ignition switch where it comes off the ignition switch and goes through the right hand switch gear kill switch. Out of the kill switch, it goes over to the LEFT HAND clutch perch where it goes through that interlock switch. When you pull in the clutch lever, it closes the loop and sends power to the starter button back on the right hand switch gear. When it comes off the kill switch, the wiring for all that mess is BLACK. It is 18 ga wire I think. In any case, the power comes over to the starter button. When you push the button, it then completes the circuit and goes to the solenoid. The voltage tickles the solenoid and causes the contacts to close and voltage flows across the solenoid to the starter.
If the starting is intermittent, start by checking connections. Start by pulling every connector in the path I described AFTER the ignition switch... Do it one connector at a time. Find the connector between the ignition switch and RIGHT HAND SWITCH GEAR that carries the power to the kill switch. It is a large multi-pin connector in the headlight shell. Open it up and clean the connectors with contact cleaner. You can buy this stuff in the computer section in Walmart and most autoparts stores. Once you clean the connectors, dab them with dielectic grease. You can buy a tube of this stuff in the autoparts store as well. This keeps the contacts free of oxidation. Anyway, look for the BLACK wire coming out of your switch gear and going to the left safety interlock switch and find its connector. Disconnect and clean/grease as before and button it back up. Do the same for the connection on the interlock switch and then follow the wire back to the starter button. Open up the switch gear. The starter button itself is often an issue. You can disassmeble it and clean the metal contacts by LIGHTLY brushing them with an emory board or steel wool. Don't get too carried away as the contact metal is thin. I would also not use dielectic grease on the button contacts as it will collect dirt in an open space like in the switch gear. Out of the switch gear, the black wire runs in the bundle to another major connector where it hooks into the main wiring harness. This connector may be in the steering neck or on the outside of the steering neck. Open, clean and grease.
Now retry the starting... If it still starts poorly, either the interlock switch is buggy OR you need a new starter button. The switch can't be serviced. You can bypass the switch to check and eliminate the switch as a problem. Unhook the wire coming off the kill switch before it hooks to the interlock switch. Then unhook the other side of the black wire loop from the interlock. Both ends will have female bayonette type connectors. Put one end of that piece of 14 ga wire into one of the female connectors and the other end into the other female connector. Don't bother pull in the clutch interlock. Just hit the starter button. If the starter spins as it should, your switch needs replaced or you can just fix a permanent jumper to replace that piece of 14 ga wire. If the starting problem persists, the starter button is the problem. Z1enterprises.com can sell you a new starter button. Drop them a note and tell them what you need as the button likely doesn't show on their web site.
I think some part of this troubleshooting should fix your problem. If not, don't hesitate to drop me a note or visit our Vintage Bike Tech Forum via our website homepage.
  • barksdaleammo
07 Mar 2007 17:38
#118210
WOW! thats a lot of info. I'm taking the bike to my shop chiefs house on sunday and he thinks he can fix it. in the next couple of weeks im going to be running around like a chicken with its head cut off. so hes going to work on it for me. ill print that out and give it to him. I appreciate all the support you have given me.
