KZ550C3 Speedometer Needle Fix?
  • jasenr
  • jasenr's Avatar Topic Author
04 Mar 2007 22:14
#117394
I have a broken needle on the speedo of my KZ550C3. How can I get in the guage to fix it? I assume it is sealed. Can anyone point me in the direction of a guide to get in there? Thanks!
  • fixer5000
  • fixer5000's Avatar
Re: KZ550C3 Speedometer Needle Fix?
05 Mar 2007 03:06
#117407
you have to peel or cut the ring that holds it together with a dremel and cutoff wheel carefully. the needle comes off pretty easy with a pair of teaspoons...i know funny but its the best tool for the job...coffee can with vinyl tape wrapped on the opening makes a good holding fixture by the way.......steve
1978 kz650b pretty much stock
massachusetts
  • Oznative
  • Oznative's Avatar
05 Mar 2007 04:35
#117413
Try this link. kzrider.com/content/view/39/11/ A very good writeup that helped me.
Post edited by: Oznative, at: 2007/03/05 07:36
1977 KZ1000 A-1 Just north of Boston
  • Oznative
  • Oznative's Avatar
05 Mar 2007 04:36
#117414
Try thhttp://kzrider.com/content/view/39/11/is link. A very good writeup that helped me.
  • jasenr
06 Mar 2007 22:53
#117980
Thanks for the pointers guys! :D
  • wiredgeorge
  • wiredgeorge's Avatar
07 Mar 2007 05:40
#118010
jasenr - If the needle is broken off, I suggest you just look for a replacement speedometer. The needle is VERY difficult to refix... it sits on a very delicate metal shaft that connects to the magnetic spring gizmo that moves it... the whole thing is kind of dainty and once the needle breaks off, I have never had much luck fixing the needle back on. The write up gets you into the gauge but I doubt you will have much luck. If you do, write up how you did it as I would be interested. I have a number of gauges with broken needles.
