Coil question
- wrecktec
Coil question
03 Mar 2007 14:23
Has anyone here ever tried using automotive coils on their bikes? I found some auto coils that have the exact primary resistance as the one on my KZ305 but the primary resistance is a little low. Just wondering what harm could be done by trying this.
- loudhvx
Re: Coil question
03 Mar 2007 14:29
I'm not familiar with the 305, but don't use a coil with lower primary resistance, only higher. Many automotive ignitions use current limiters to protect the coils. KZ's do not. If the coil primary is too low, you can burn the coil or the ignition or both.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- kzwolfsr
Re: Coil question
03 Mar 2007 14:58
Nothingelse needs to be said on that, Loud said it all
Original man of the Caribbean
- wrecktec
Re: Coil question
03 Mar 2007 15:14
I'm sorry, I worded that worng. The primary resistance is right on the money. The secondary resistance is what is a little low.
- loudhvx
Re: Coil question
03 Mar 2007 15:44
If the primary is the same, then there's a chance it will work. The next consideration is if it was meant to be used with a current limiter.
Most car coils have a much lower primary resistance than KZ coils. KZ's are in the 2.5 ohm range, car coils go down to the 0.5 ohm range.
What car is the coil from?
1981 KZ550 D1 gpz.
Other links.
Other links.
- wrecktec
Re: Coil question
03 Mar 2007 16:06
Primary resistance on my orignal KZ coils and the auto coils measures 3.8 ohms. Secondary measures 11 ohms on the orignal KZ coils and 6 someting ohms on the auto coils. The auto coils I have say on them "no external resistor requrired" which i guess means u do not have to run a ballast resistor or resistor wire in the primary circuit.
- pstrbrc
- '81 GPz 1100 project
Re: Coil question
03 Mar 2007 16:09
OK, you've piqued my curiosity. What auto coils are you looking at?
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
Elkhart, Kansas USA
- loudhvx
Re: Coil question
03 Mar 2007 16:45
If it's 3.8 ohms, the coil is for points.
Does the KZ305 use points? Even in 1982?
1981 KZ550 D1 gpz.
Other links.
Other links.
- loudhvx
Re: Coil question
03 Mar 2007 16:52
loudhvx wrote:
The KZ305 CSR is a 180 degree motor. This means it uses two single-output coils, like an old car coil. It is also points-operated, even in 1982.
So if the car coil is really 3.8 ohms, at least the points shouldn't get hurt, so it's worth a try.
Well, I looked it up on buykawasaki.com.If it's 3.8 ohms, the coil is for points.
1981 KZ550 D1 gpz.
Other links.
Other links.
- OKC_Kent
Re: Coil question
03 Mar 2007 17:04
Or buy this ebay coil that ends in 3 minutes.
tinyurl.com/2gsv8j
Post edited by: OKC_Kent, at: 2007/03/03 20:06
tinyurl.com/2gsv8j
Cashion, OK
78 KZ650 B2 85,000+ miles
- wrecktec
Re: Coil question
03 Mar 2007 17:06
I figured it is worth a try, considering you can buy these coils for about $20 each. I went to a good local auto parts store and bought solid core non-supression spark plug wire,termanal ends, and misc to build new wires for under $4. Bought new NGK resistor boots for about $4 dollars each. This seems like it is much cheaper than any other alternitaves i can come up with.
- wrecktec
Re: Coil question
03 Mar 2007 17:09
BTW OKC Kent, that is one of my old coils for sale. The other one had a broken wire which i could'nt do anything with.
