Can I use a different electric tach?
  • OKC_Kent
  • OKC_Kent's Avatar Topic Author
01 Mar 2007 15:42
#116517
My 83 750 uses an electric tachometer and I need one, and they seem to be very rare; it is shared with the 550 LTD of that year too.
Would anyone know if an electric tach from a different Kawasaki will work? I guess it reads a signal from somewhere to trigger it, would that signal be common among electric tachs by Kawasaki?
Hopefully I could find a newer style to pop on the bike, maybe with a matching speedometer too?
Cashion, OK
78 KZ650 B2 85,000+ miles
  • loudhvx
  • loudhvx's Avatar
Re: Can I use a different electric tach?
01 Mar 2007 20:43
#116589
Yes, it just reads the signal from one of your coils. Even one from a 750 twin would work (if they had them). Any tach that reads one pulse per revoltution will work. That should mean most KZ's through the mid eighties which used electric tachs.
Car tachs for 4-cyl motors using a distributor usually require 2 pulses per revolution, so you'd need an adapter for car tachs.
I don't know if the later cop bikes used the same type of tachs.
Post edited by: loudhvx, at: 2007/03/01 23:47
  • OKC_Kent
02 Mar 2007 04:44
#116638
Thanks Lou, you just made this a lot easier for me. Now I have something to look for when I'm e-baying.:)
Cashion, OK
