Coil mod.....
- indykaw77
Coil mod.....
27 Feb 2007 15:18
OK....didnt this mod USED to have one of the relay lugs connected to one of the wires from the KILL switch? Waiting on my new fuse block and got to checking stuff.....just want to make sure I have mine wired up right and WASNT imagining another "wire-up" technique....
Kawasaki Motorcycles...because cars lean th wrong way!
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
Re: Coil mod.....
27 Feb 2007 16:00
I've always connected it to the red/yellow wire that WAS powering the coils--which comes from the kill switch, I believe.
West Linn, OR
- rstnick
Re: Coil mod.....
27 Feb 2007 16:17
Skyman is correct. The wire going to the coils gets wired up to lug #86. Just disconnect the plug/s that the coil feed wires plug into, and run a single wire to lug #86.
Then from lug #87, run a wire back to the coils, which will need to have a dual female plug to plug in the 2 coils.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- indykaw77
Re: Coil mod.....
28 Feb 2007 08:08
I see it now (I think)....the diagram w/ kill switch is slightly different than whats in the filebase now. When I did mine, it was per the kill switch diagram. Just wanted make sure I had it correct.....
