BRAKE LIGHT OUTAGE UNIT
  • z1kzonly
  • z1kzonly's Avatar Topic Author
22 Feb 2007 18:56
#114608
Hi I have 2 brake light outage indicators!
They both have different readings with the multi-tester.
The manual does not have a check!
They are Koito Part # 352-71713.
Have the black, green and yellow wires.
They are longer than the 76 KZ900 model
Any info???????
Marty in Buffalo
  • wiredgeorge
  • wiredgeorge's Avatar
Re: BRAKE LIGHT OUTAGE UNIT
23 Feb 2007 04:42
#114678
Marty, Not sure what part you are referring to... are you asking about the little gray plastic box that sits above you valve cover and is tied to the harness up between the frame rails?
  • loudhvx
  • loudhvx's Avatar
23 Feb 2007 11:18
#114776
Readings on the multitester will vary on that device. They are not all the same and because they use solid-state devices, even units that are identical can have different ohm readings. You really just have to try them out.
