bicycle speedometer?
- kzwolfsr
09 Feb 2007 17:58
Can one of those work for my 1000? I've seen post here about it , but does anyone really have one that works, like the cordless ones?
Original man of the Caribbean
- kawsakiman
Re: bicycle speedometer?
09 Feb 2007 18:20
i've yet to find a pedal bike that can do 100mph:lol:
- kzwolfsr
09 Feb 2007 18:37
The speedos I had can go above 100mph but they were corded
- caffcruiser
09 Feb 2007 19:31
Yes they will work.
No it is not recommended.
Illumination is a problem.
Yes, they are more precise than a motorcycle speedometer.
- Urbandrag
10 Feb 2007 00:44
I had a BC800 model in my ZX11 before my VR2. It worked great!... But I don't know if they still make this unit. I think modern units are backlighted.
Here is Sigma's website: www.sigmasport.com
- pyxen
12 Feb 2007 06:33
I've got one on my KZ right now..but the problem I'm having is that the pickup isn't strong/precise enough to track the speed over 60mph. I'd see it fluctuating between 60 and 80mph, when I knew I was doing at least 80mph (~130kph).
It goes up to 99mph, which is plenty fast for me..above 100mph, does a specific speed really matter anymore?
I've moved where the pickup is attached on the fork leg, and I'll see how it works this year, but I was happy with it while I used it..and yeah, illumination is a problem. I thought about opening up the computer unit and backlighting it with an LED, but haven't done that yet. I may just get a small booklight or something and point the light at it instead.
Mine's wired, and it isn't that big of a deal - there are two other cables running in the same direction already.
This is it. And I'm using a strong earth magnet instead of the magnet that comes with it. The magnet fits perfectly in the holes in the brake rotor (between the bolts - not on the brake surface itself!) - nice and tight, and flush - it's like it's made for it
Post edited by: pyxen, at: 2007/02/12 09:37
84 KZ550-F2 LTD
93 ZR550-B4
93 ZR550-B4
