Help Aftermarket ignition
- Qdude
- It is all good.
05 Feb 2007 05:42
There is a white wire that comes off of the assembly that replaces the points mount on the right side of the engine.
I kept track of all other wires, but didn't realize that the small wire coming from the right side of the engine was aftermarket. I thought that I could re-attach it using the Kawasaki owners manual.
Web searches come up with mortgage companies. It is a "Mortek Products Inc. Santa Ana Ca". That is the only identifying mark on the thing.
I have no manual for the aftermarket ignition thingy.
I don't know where the thin white wire goes.
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
- steell
Re: Help Aftermarket ignition
05 Feb 2007 07:03
Try searching for Martek ignition, or if you search here on KZR you'll find it
HERE
- pumps
05 Feb 2007 07:10
Its actually "Martek " I would bet. Google will pull up some stuff on Martek but try
here.
Ok Steell , ya BEAT me!
Post edited by: pumps, at: 2007/02/05 10:11
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
1977 Yamaha XS650
2000 Kaw W650
- steell
05 Feb 2007 08:10
pumps wrote:
Great minds think alike
Its actually "Martek " I would bet. Google will pull up some stuff on Martek but try here.
Ok Steell , ya BEAT me!<br><br>Post edited by: pumps, at: 2007/02/05 10:11
- Qdude
- It is all good.
05 Feb 2007 18:44
Thanks for the links guys, I don't know why I was having problems googling Martek, but I came up goose eggs.
I gave my best guess as to where the last wire went, and guessed correctly. Upon completion of a total core rewire, it started right up, smooth as silk. I fixed all of the accesories as well!
Still not charging though.
Thanks again for the help you two!
Q
Q
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
