Regulator/Rectifier mounting?
- greatbeefalo
02 Feb 2007 11:59
Ive looked all over (even in the manual) and I cant find a clear picture of the mounting place for the fuse box and the regulator/rectifier on a 78 KZ650. Could someone take a picture, or point me in the right direction, of the mounting places for the electrical components beneath the side cover?
- OKC_Kent
Re: Regulator/Rectifier mounting?
02 Feb 2007 12:10Under the left cover on my 78 B2 650.
Also be sure the connection in the white square is very clean. Corrosion here will cause problems in the charging system.
The original fusebox goes in this area under the right cover, but try to upgrade to a blade style fuse holder. I have a 6 blade that just uses 3, with 3 spares. You can pick these up cheap at any auto parts store. Easy to hook up too.
Post edited by: OKC_Kent, at: 2007/02/02 15:14
Post edited by: OKC_Kent, at: 2007/02/02 15:19
Cashion, OK
78 KZ650 B2 85,000+ miles
- greatbeefalo
