900cows wrote:
    I have used a test light in between battery post,and cable.test light should be lit.Pull each fuse,if there`s a problem in the circuit/circuits the light will go out.If its in another circuit,the test light will stay lit.
Is that between the positive cable and post or the negative? That may be a quick way to narrow it down
