Repowering coils KZ650
  • Larry2882
  • Larry2882's Avatar Topic Author
30 Jan 2007 15:25
#109213
Did anybody ever try wiredgeorge's recommendations on repowering coils via automotive relay? I'm going to give it a shot if I can find out which kind of relay,kind of auto,and where it is located in the vehicle.If anybody knows,email me or better still post on the forum.
  • KaZooCruiser
  • KaZooCruiser's Avatar
Re: Repowering coils KZ650
30 Jan 2007 16:46
#109234
Do a search for "coil mod" It's all over the place.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
30 Jan 2007 17:05
#109239
I did it using a relay bought in Canadain Tire that was for adding lights to a vehicle. Mine was a 5 pin relay with two #87 outputs. They also had a 5 pin pigtail for this relay which helped in wiring it up.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • indykaw77
  • indykaw77's Avatar
30 Jan 2007 18:19
#109258
Here's the scoop...
kzrider.com/component/option,com_docman/.../gid,106/Itemid,231/
Download the file....read and follow directions. Happy wiring!!
Kawasaki Motorcycles...because cars lean th wrong way!
  • outatimeoutlaw
  • outatimeoutlaw's Avatar
03 Feb 2007 14:38
#109965
WIREGEORGE Has the best solution & it used to be on his site ,but it's not there anymore . It is simple to wire the coils through a standard automotive relay,That way the starter wont rob current from the coils.Go to your auto parts store & ask to see a fuel pump relay for a 1995 ford van.almost all of these relays have tha wireing diagram on the side & you can fgure out from there what is going to work.
Post edited by: outatimeoutlaw, at: 2007/02/03 17:46
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
03 Feb 2007 15:16
#109971
Yep, seriously. Do it. You won't regret it. Here's a recent thread on it with a link (in my post) to a great place to buy the relays and pigtails online....
kzrider.com/component/option,com_joomlab...,4/id,106951/#106951
Post edited by: Biquetoast, at: 2007/02/03 18:20
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • wiredgeorge
  • wiredgeorge's Avatar
03 Feb 2007 16:04
#109986
The Coil Repowering how-to is better written on our web site... cleaned up...
It is still there:
www.wgcarbs.com/59021.html
  • brianrae33
  • brianrae33's Avatar
04 Feb 2007 09:15
#110120
what if your electric start is totally disconnected...no loss of current there...couldn't i just run a hot wire from the fuse block or the starter relay??
1982 kz1000ltd
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
04 Feb 2007 13:48
#110175
Yes.
The Relay is powered from the starter relay solenoid, with a in-line fuse, to pin #30 on the relay, in WG's coil rewire.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • brianrae33
04 Feb 2007 14:51
#110191
sorry...meant would a relay still be needed for the additional power?
1982 kz1000ltd
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
05 Feb 2007 06:30
#110299
Wiring it up using a relay still allows the kill switch to work, being able to turn the relay on and off. The power does not flow through the kill switch anymore, causing loss of power, but the kill switch still can kill the circuit.
Without the relay, and wiring directly to the coils, you would not have an off/kill switch. I suppose you could wire something up, but now your talking an other set of wiring circuits to figure out.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
