kz 1000 ign swap question
  • djnubz
  • djnubz's Avatar Topic Author
28 Jan 2007 17:36
#108839
is it possible to just swap the ignition from a 81 kz1000 to a 77? If so can I keep my stock coils?
  • wireman
  • wireman's Avatar
Re: kz 1000 ign swap question
28 Jan 2007 19:55
#108868
im pretty sure 73 to 80 interchange,but im thinking the 81 is a j motor isnt it?;)
  • 1045
  • 1045's Avatar
28 Jan 2007 20:49
#108876
I am not sure if a 81 1000 has the same ignition system as the 81 750 but i put the 81 kz 750 ignition system on my 77 1000. I used the 81 coils also. The only thing I had to make was a new backing plate for the pick-up coils to mount on my bike. Works good.
1045
1045
  • trippivot
  • trippivot's Avatar
31 Jan 2007 05:22
#109335
J or Z 1000s' and 900s' they interchange freely points to electronic or vice versa. I keep a points set up in the saddle bag in case of ign. brain failure
750 to 1000 needs a bit of modification of the crank pick up backing plate
  • djnubz
31 Jan 2007 11:04
#109386
so I can get an electronic ignition to replace the points on my 77 kz1000 from a 80 kz1000. Awesome. Do I have to swap the coils as well?
  • trippivot
31 Jan 2007 13:03
#109400
dont have to but if you want to yes
I like the coils that the wires are removable.
as long as there are two primary leads(small)
and two secondary leads (big)
they'll work a ok.
the brain from a kz 750 hooked to the pick ups off of the kz 1000.
then the box to the coils can even keep black as 1,4 and green as 2,3
Post edited by: trippivot, at: 2007/01/31 16:11
  • trippivot
31 Jan 2007 13:14
#109405
here is a peep
  • wiredgeorge
  • wiredgeorge's Avatar
31 Jan 2007 13:14
#109406
I would swap coils as well as swapping the ignition IF the ignition came from a bike that used a inline ballast resistor to power the coils. In this case, the coils will be lower impedance so you would have to use the ballast resistor and the coils or not use the ballast resistor and stay with your old coils (the 77 had 3 ohm coils).
