'76 KZ900 Rectifier
  • KZ900AG
  • KZ900AG's Avatar Topic Author
'76 KZ900 Rectifier
12 Oct 2005 13:31
#1082
Does anyone know where I can get a rectifier for my KZ900 for a reasonable price?
  • savedrider
  • savedrider's Avatar
  • 1975 Z1-B 900
Re: '76 KZ900 Rectifier
12 Oct 2005 16:07
#1143
Shucks, I just put one up on eBay today...good working unit, but not sure if it is compatible with the '76 KZ 900.
If your interested... cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&rd...ageName=STRK:MESE:IT
Get right or get left! <*{{{><
  • Kawozaki
  • Kawozaki's Avatar
12 Oct 2005 19:30
#1195
Jeff Saunders at Z1 Enterprises sells a regulator/rectifier combo unit that is reasonably priced. Check with him...he probably has a stand alone rectifier, too.
Oz
  • GargantuChet
  • GargantuChet's Avatar
12 Oct 2005 19:58
#1206
Z1 has them for $90-$100. Unfortunately I need one also (different type than yours), and none of the bikes being parted out in the site classifieds have rectifiers that'll fit either of our bikes.
Bikebandit wants ~$280 for the OEM rectifier for my bike. Jeff's prices sound a lot better compared to that! :ohmy:
Please let me know if you find a cheaper source. I should call the local bike salvage yard...
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
13 Oct 2005 17:47
#1491
www.z1enterprises.com/detail.aspx?ID=1873
This r/r unit is one of the most popular for the early KZ1000's and KZ900's as it is a plug replacement - and reasonably priced. I've been using the equivilent one on my turbo bike for the summer and it works great.
This email address is being protected from spambots. You need JavaScript enabled to view it.
Z1 Ent on Facebook,
  • dutchz
  • dutchz's Avatar
13 Oct 2005 19:31
#1529
The cool thing about the one Jeff sells is, like he says, it's a plug-and-go thing. I couldn't spend $90 right now - too many upgrades :whistle: so I got a 86 Ninja reg/rec at the scrapyard for $30, and wired it in with some guidance from Loudhvx.
It starts & idles fine I'm about to take it out on a test drive with running lights. I'll let you know how it goes...
I cut the old connector of my regulator so I didn't have to harm the main wiring harness, wired the stator and brown wire into it and added an extra fuse on the brown wire for added security but it's REALLY straightforward otherwise.
-dutch
1974 Kawasaki Z1
Stock front hub and rear axle.
  • dutchz
  • dutchz's Avatar
13 Oct 2005 21:10
#1575
Well, she runs like a charm, with headlight, blinkers and all. Seems like the power supply is actually more consistent but I might just be imagining it. I get a very steady 14.5 reading accross the battery terminals on idle. The headlight is bright even when on idle (did already do a H4 conversion couple of weeks ago... night and day)
-dutch
Post edited by: dutchz, at: 2005/10/14 00:11
Post edited by: dutchz, at: 2005/10/14 00:12
1974 Kawasaki Z1
  • GargantuChet
13 Oct 2005 23:15
#1601
That's good stuff. I'm kind of a stock bigot, so I'll probably just call the local boneyard and try to find an OEM one, and failing that I'll buy from Z1.
You should post something about the reg/rec installation, though, since I'm sure a lot of people would benefit from the information.
By the way, how much did you spend on the H4 conversion? My headlight SUUUUUUUUUUCKS, but it might also just be the reg/rec not feeding it properly.
  • dutchz
  • dutchz's Avatar
14 Oct 2005 11:10
#1721
I think I paid just under twenty bucks for the conversion kit, bought on Ebay from RicePaddy. The have these kits on there all the time. Mine worked great even with the stock reg/rec setup.
-dutchz
1974 Kawasaki Z1
