Headlight
  • KZSteelers
  • KZSteelers's Avatar Topic Author
Headlight
20 Jan 2007 19:20
#107179
I was wondering if anyone could give me some insight on my headlight. I replaced the bulb for it a while back, thinking a halogen bulb would give me some more light.
My headlight sucks. Is there a better bulb that I havent found yet, or do I possibly have an electrical problem?
Re: Headlight
20 Jan 2007 19:54
#107185
Here's a good recent thread on headlight replacement
kzrider.com/component/option,com_joomlab...mit,20/limitstart,0/
  • dkmk
  • dkmk's Avatar
Re: Headlight
20 Jan 2007 23:30
#107205
My 650 had already been converted from the sealed beam when I bought it. Tried an 85/100, but was too much for the system. Clamped an ammeter on the main wire to the fuse panel, was drawing over 15A, and had blew a fuse or two.
I replaced the standard H4 bulb with a GE Nighthawk halogen (55/60). The difference was, well, night and day :P . Considerably more expensive at about $25 a bulb, but well worth it. More on the GE bulbs here:
GE Nighthawk bulbs
Here are the images from the above site:
Nighthawk headlight
They may look exaggerated, but they are representative of what the bulbs are like.
Post edited by: dkmk, at: 2007/01/21 02:38
Northern Ontario
Zapp: "Kif, I'm feeling the Captain's Itch."
Kif: "I'll get the powder, sir."
  • dkmk
  • dkmk's Avatar
Re: Headlight
20 Jan 2007 23:36
#107206
Ooops! :laugh: Wrong pic. Here is the standard headlight image from the GE site:
Northern Ontario
  • Samwell
  • Samwell's Avatar
Re: Headlight
21 Jan 2007 02:38
#107208
The nighthawk bulbs are a nice upgrade, but its worthwhile checking things out. Clean all the contacts involved from the battery to your headlight socket. Measure the voltage(with key on) at the battery and at the headlight.
If the voltage is good and connections are fine, make sure your head light is properly adjusted for beam height.
Sam
  • pstrbrc
  • pstrbrc's Avatar
  • '81 GPz 1100 project
Re: Headlight
21 Jan 2007 05:46
#107211
On the previous thread ("Headlight passed away") there was a question about different light dispersion patterns between motorcycles and cages. Used to be true. Europe had different standards of pattern for auto than the US did. Over the years these have merged. It's the same pattern. Buy a good headlight lens/reflector unit at an auto supply store, then go to WalMart and buy the best bulb that fits it that you can afford.
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
  • KZSteelers
Re: Headlight
15 Feb 2007 16:23
#112689
Thanks for the help guys, its much appreciated.
I read about a VW golf headlight, and a sylvania bulb...I think I'll give that a shot and see where it gets me.
We've got about 2 feet of snow here in Western PA. My storage shed / dad's airplane hangar is snowed in, so it will be a while before I can get over to the airport and work on it. Bike doesnt like to start when it is a whopping 15 degrees for your high, too.
Thanks again guys :-D
