Spark Plug Wires
- bullitt00692
Spark Plug Wires
20 Jan 2007 17:13
I have a stock 82 KZ440 and need to replace the plus wires.
What do you recommend?
The wires are screw on to the coil.
Will car plug wires work or does this KZ require special?
Solid copper or stranded?
I have the screw on boots that are new, so just need the wires.
Suggestions?
Thanks!
Suggestions?
Thanks!
- Bluemeanie
Re: Spark Plug Wires
20 Jan 2007 17:18
What kind are on now?:dry: I have regular Accel automotive on mine...
Post edited by: Bluemeanie, at: 2007/01/20 20:18
- bullitt00692
20 Jan 2007 18:59
I have no idea what type of wires on it now. It looks like stranded copper, but I am not really a wire expert.
- Bluemeanie
21 Jan 2007 05:53
Someone else needs to chime in but I would think that the "screw" in type would work better with metal stranded wire? Anybody...:dry:
- Samwell
21 Jan 2007 06:02
He's got new plug caps/boots, the stock coils are in good shape, so the regular stranded wire should do just fine. He wouldn't notice a performance diff with the fancy 8mm carbon cored whatevers. Brnad new basic wire will conduct a lot nicer than his old stockers.
"chime...."
Bluemeanie wrote:
"chime...."
- Bluemeanie
21 Jan 2007 11:06
There ya go bullit, nuff said...
- kzwolfsr
22 Jan 2007 19:59
Yep its copper stranded. If you want to use car wire, just make sure it has the same amount of resistance or close. Too much or too little can cause problems. I have been thinking about the same for my 81 kz1000
Original man of the Caribbean
