82 KZ1100 coils
  • wagonmaster69
  • Topic Author
  • 78 KZ1000A2 / 82 KZ1100 Spectre
19 Jan 2007 14:22 #106877 by wagonmaster69
82 KZ1100 coils was created by wagonmaster69
Not sure if I ask this before but will coils from a 82 KZ1100 Shaft work on a 78 KZ1000 A2? And let me know why if they will or not thanks..
19 Jan 2007 17:46 #106901 by wiredgeorge
Replied by wiredgeorge on topic 82 KZ1100 coils
Dunno for sure but if I wanted to know, I would go to kawasaki.com and look at the ignition systems for both bikes. This get complicated so pay attention....
You have either an electronic ignition or points. This requires ~4 Ohms resistance at the coils. To get this impedance, you must have ~4 Ohm coils (folks generally call these 3 Ohm coils) OR 2.5 Ohm coils and a 1.5 Ohm ballast resistor. The power will come off your fuse block and through the ballast resistor and then over to the coils via a circuitous path. If you have a bike with the 2.5 Ohm coils, you must use the ballast resistor to get the primary impedance up.
OK... Say your donor coils are 4 Ohm. How would you know? Either measure their primary impedance OR look for the ballast resistor. It will be a white piece of ceramic about 3" long mounted on the battery box or between the frame members near the horn. If you find the ballast resistor, you have 2.5 Ohm coils. If you don't then you likely have 4 Ohm coils.
If you want to use these coils on another bike, you have to know what you have and can't use them without the ballast resistor as well, if they are 2.5 Ohm coils. If they are 4 Ohm coils, install them without the ballast resistor.
Well? You asked why ehehe... probably would have been easier to go look the bikes up on kawasaki.com rather than type all this.
  • wagonmaster69
  • Topic Author
19 Jan 2007 20:54 #106975 by wagonmaster69
Replied by wagonmaster69 on topic 82 KZ1100 coils
Do you mind repeating that?:whistle:
I guest I have to check all that out.
