handlebar switch restoration
- Tancred9
08 Jan 2007 18:32
I am in the process of giving my 77 KZ1000A a major clean up and would like to have the handlebar switches repainted keeping the original recessed white and yellow lettering - anyone have this done before? Anyone recommend someone to do this?
regards
regards
- pumps
Re: handlebar switch restoration
08 Jan 2007 19:54
On my KZ they are fine but have another bike that the letters are worn off. I looked for something to stick on with no success.
On the KZ if they are recessed (mines not here for reference) I don't know why you couldn't get a small brush and do it yourself? Wipe off the excess?
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
1977 Yamaha XS650
2000 Kaw W650
- Sandy
- Fly High,Tony
08 Jan 2007 20:03
Tancred9 wrote:
Ya...YOU!
Seriously...sand off the old paint,and have at er,Bud!
For the white and yellow colouring...use the tip of a pin or a toothpick,or something that size.
Do the base coat first...let it set up and cure properly,and then take Your time,and do Your Own touch-ups...You'll see...You can do it.
And welcome to KZR!!
Post some pics of Your bike,Tancred9B)
regards
Ya...YOU!
1977 KZ1000 A-1
- donthekawguy
08 Jan 2007 21:05
I painted mine silver and then cut a bunch of the brissles off of a small brush. It took a few tries but they came out good. I used lime green for all the lettering BTW.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- H1Vindicator
Last edit: 21 Feb 2013 21:06 by H1Vindicator.
- ltdrider
09 Jan 2007 07:29
I used a small wire brush to scuff up the control, and dug out the paint from the lettering recesses. Then I painted everything black. Then I used water-based paint, and dabbed it into the lettering with a small brush. Then wipe off the excess with a damp cloth. I did this two years ago, and the switches still look good.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- pumps
09 Jan 2007 08:27
ltd looks really good.
Ok let me throw this at you.The lettering on my KZ controls is fine but on my Yamaha they are completely worn off. I think they were just on the surface to begin with because if you look at just the right angle you can make the letters out. I made the rounds of the hobby stores looking for small white letters to maybe rub/stick on there, then my idea was to paint clear by hand over them . Problem is I can't find any small letters.You know they've got to be pretty small.
1977 Yamaha XS650
2000 Kaw W650
1977 Yamaha XS650
2000 Kaw W650
- elseed
09 Jan 2007 09:03
I dunked mine in the (hideously caustic) carb cleaner solution -- this removed paint to bare metal, then repainted. Had a buddy at work, the figure-painter hobbyist, do the fine stuff like LTDRider shows. I believe he used a fine brush and also did a wipe-off, then clear coated to help preserve it.
Incidentally, it's supposed to be 78F today and I'm going riding (again).
'75 Z1B with mods
- arobsum
09 Jan 2007 09:21
ltdrider wrote:
damn, good job! it does look new..I used a small wire brush to scuff up the control, and dug out the paint from the lettering recesses. Then I painted everything black. Then I used water-based paint, and dabbed it into the lettering with a small brush. Then wipe off the excess with a damp cloth. I did this two years ago, and the switches still look good.
- ltdrider
09 Jan 2007 10:10
Here's the left side. The photo is just a little fuzzy, but the letters on the control came out clean and sharp.
Post edited by: ltdrider, at: 2007/01/09 13:11
Greensboro, NC
Greensboro, NC
- 900cows
09 Jan 2007 11:16
Use a tooth pic,just a dap,then wipe.....practice.
- arobsum
