Main Wiring Harness - Routing?
  • floridamba
  • floridamba's Avatar Topic Author
06 Jan 2007 14:19
#103767
My 82 1000ltd has the main wiring harness on the left side of the triple tree - when I go full-lock left the triple clamp pinches the wiring. This is not good.
How should this route? Under the bottom triple clamp and under the plastic badge and into the headlight?
If so, what is the best way to do this, drop the wheel and pull the forks down or disconnect and reconnect a gazillion wires?
many thanks in advance
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: Main Wiring Harness - Routing?
07 Jan 2007 08:29
#103928
A shot in the dark here, since I'm not experienced with your model but I believe that most KZ's have the harness routed on the left side. Are you sure that you can't just use some cable wraps to hold the harness out of the pinch zone?
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • arobsum
  • arobsum's Avatar
07 Jan 2007 08:36
#103932
KZCSI
yep...both my kz's are routed to the left as well. maybe you could pull up some slack somewhere?
