dyna-s on 81 550
  • brianrae33
  • brianrae33's Avatar Topic Author
dyna-s on 81 550
05 Jan 2007 09:01
#103507
just bought a dyna s ignition for an 81 kz550...just wondering if the ignitor is bypassed...don't think it can be but figured i'd check with you guys first...thanx in advance..
1982 kz1000ltd
  • SpokeWheel650B
  • SpokeWheel650B's Avatar
Re: dyna-s on 81 550
05 Jan 2007 09:33
#103518
The Dyna S is a totally self contained unit ie: no external ignitors. Pretty simple to set up to, a good move if your stock stuff is giving you trouble:evil:
best to all,
Ray
  • loudhvx
  • loudhvx's Avatar
05 Jan 2007 10:11
#103525
Which 550 do you have? In 81, the D (gpz) and C (ltd) had ignitors and 2.5 ohm coils, I think. The 81 A (standard) had points and 4 ohm coils. The Dyna-S is more suitable with the 4 ohm coils. Dyna doesn't recommend using the S with coils less than 3 ohms.
  • brianrae33
05 Jan 2007 18:40
#103639
have the c model..(ltd)
1982 kz1000ltd
  • SpokeWheel650B
05 Jan 2007 19:13
#103648
loudhvx wrote.....The Dyna-S is more suitable with the 4 ohm coils. Dyna doesn't recommend using the S with coils less than 3 ohms.
OH, man did I miss that:blush: Good catch, loudhvx!;)
all the best,
Ray Kelley
  • loudhvx
  • loudhvx's Avatar
06 Jan 2007 17:43
#103830
all the best,
Ray Kelley
At least one member reports the Dyna S works ok with the 2.5 ohm coils, Dyna just doesn't recommend it.
