coils
- mustache
coils
04 Jan 2007 16:29
hey guys
hadn't been on here much lately but its a new year and i'm think about my bike again.
i am going to buy a new set of coils. looking at some at z1 enterprise.not sure the ones i need. i think its the dyna dual output 3.0..my bike is a kz650b 1978.
if this is what i need will they work with my stock points..any help will be appreciated..mustache
- RetroRiceRocketRider
Re: coils
04 Jan 2007 16:41
Yes, the Dyna DC1-1 3.0 ohm coils are the ones you'll want. They should work fine with your points system, but you'll notice a bigger diff if/when you swap to either the Dyna-S electronic ignition, or the electronic ignition from an '81 KZ650-F1 or '81~'83 KZ650-H CSR.
The bummer is the Dyna 3.0 ohm coils show as being "temporarily out of stock" at Z1Ent.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- mustache
Re: coils
04 Jan 2007 16:55
i thank u for the feed back..they are out of stock at z1..are there any place else i can buy some or do they stay out of stock very long. if not i can wait...thanks again
- mustache
Re: coils
04 Jan 2007 19:54
i found a place on ebay that sells the dyna coils..it said for older bikes with points that dyna recomends 5.0 coils. can any one conferm this to be true or not true..thanks for any help
- wiredgeorge
Re: coils
05 Jan 2007 05:12
At this time of the year, suppliers typically have closed for a week or two, such as Dynatek. While z1enterprises.com may be out of the coils today, they likely will be getting some in the very near future. Try calling Jeff, the owner and finding out. I suspect they would arrive just as quickly from Z1Enterprises as the namesless eBay seller. Also, get the green 3.0 Ohm coils. They are the correct coils.
- steell
Re: coils
05 Jan 2007 05:31
What Dyna actually says according to their
web page
At the top of the page though, Dyna says
If you search this entire site I don't believe you will find recommendations for anything but three ohm coils for the KZ's.
Post edited by: steell, at: 2007/01/05 08:32
DYNA 4000 Pro Ignition
Must use DC9-1 or DC9-2. The DYNA 4000 ignition system is designed for racing only and is matched to the characteristics of the DC9-1 coil for optimum energy production.
Recommended - DC7-1, DC8-1, DC10-1, DC3-1, DC6-1. Use coil with 5.0 ohms primary resistance for street use, 3.0 ohms primary resistance for racing applications.
Before selecting a coil, check the coil primary resistance requirements as specified by the manufacturer of the ignition being used.
- loudhvx
Re: coils
05 Jan 2007 10:40
Like everyone already said, you'll want the 3 ohm coils. They have the widest range of uses. They'll work with points, the stock electronic ignitions, and the Dyna S ignitions.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- mustache
Re: coils
05 Jan 2007 17:12
i would like to thank everyone for all the help.this has been a big help..thanks to you all..mustache
