electronic stock ignition with advacer help
- stresser
28 Dec 2006 16:23
can anyone tell me what would i need to use this on my 77KZ1000,electronic stock ignition with advacer from a
1981'Kawasaki CSR-1000/KZ-1100/LTD i saw one on ebay and wondering if i could us it stand alone like a dyna or if i need other components any help would be great
thanks in advance brothers of the Z
tony
tony
- rstnick
Re: electronic stock ignition with advacer help
28 Dec 2006 16:26
Click the link in my signature that says "kz1000 elec. Ign."
I did this change on my '78 650.
One difference in your case would be the advancers. They should be a dirrect swap, with no modifcations needed.
As well, the back plate would be a dirrect swap, where as the 650's is smaller.
Post edited by: rstnick, at: 2006/12/28 19:32
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- stresser
28 Dec 2006 18:24
thanks for the assist but i lost the auction any idea if one from a kz750 would also be the same?
thanks:blush:
thanks:blush:
- rstnick
28 Dec 2006 19:20
The one from a 750 would use the smaller mounting plate like the 650, so mounting it on a 1000 can be tricky. I could make the 1000's smaller to fit my 650, but how are you gonna make one bigger to fit the 1000? You may be able to use your existing mounting plate, but there are holes that would need to be drilled and tapped for the differences between the points and pick-up coils.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
