Proform Shift Light
- bkitchen
Proform Shift Light
28 Dec 2006 12:12
I bought a Proform shift light off of Ebay last week($25 ended xmas eve night). I hooked it up and am having a problem with it. It is a stand alone shift light, No tach needed. Only 3 wires to hook up, positive wire, ground wire, and a wire to the negative side of the leading coil. When I set the dial to around 1000RPM it doesn't come on until about 7000RPM. Like it isn't getting enough signal. You jump 2 different wires depnding on if it is 4,6,or8cylinders. (Now as I am writing this I am wondering if I could jump it as a 6 or 8cylinder and get a closer reading) Any experience with these?
- loudhvx
Re: Proform Shift Light
28 Dec 2006 21:16
If the light is for a car, the light will come on at twice the RPMs it's set for. That's because a car has a distributor instead of using two coils. A 4-cyl car-coil fires twice per crank revolution, the 4-cyl bike-coil fires once per crank revolution.
If you set it to 1000, it should light up at 2000 (in 4cyl mode). In 6-cyl mode, it will light up at 3000. In 8-cyl mode, it will light up at 4000.
Why at 7000? Not sure. Maybe hook it up to the other coil and see what happens.
Post edited by: loudhvx, at: 2006/12/29 00:22
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- bkitchen
29 Dec 2006 04:40
I jumped it as a 8cy and it brought it to within 1000RPM of what I set it and where the tach reads. Thanks
