1981KZ 1000
- ronkz1000
1981KZ 1000
28 Dec 2006 05:36
I dropped it an the ingnition cover got broken along with the timing advance plate. I replaced it with the timing advance plate off an 1980 classic fuel injected bike. Now it has no power. I'm wondering if I need an timing advance plate specific for the 81 carb. bike.
Help:S
Yes it has electronic ing. It's an LTD model. The timing advance assembly is free but came off the classic bike I don't have or know where to get one for the LTD bike.
Post edited by: ronkz1000, at: 2007/01/15 11:26
Help:S
- cratgo
Re: 1981KZ 1000
28 Dec 2006 05:50
i'm afraid it's time to get your tester out.
sounds like you just need to fine tune the breaker point gap and the contact, opening/closing, if you don't have one, (everybody should have one) u should get a simple continuity tester that beeps. thats a good way to do the adjustment, i think
- steell
Re: 1981KZ 1000
28 Dec 2006 06:50
cratgo wrote:
Did you replace the timing advancer, and if you did does the new one rotate freely?
Are you sure that the new advancer (assuming you replaced it) was lined up correctly on the pin, and that the pin was not bent(I'm assuming that the 1000 does use a pin to locate the advancer)?
Post edited by: steell, at: 2006/12/28 09:54
With an 81 1000 he should be talking about electronic ignition, not points.i'm afraid it's time to get your tester out.
- steell
Re: 1981KZ 1000
28 Dec 2006 06:56
Part number 92043 is the pin.
The part numbers for the advancers are different between the 80 KZ1000G1 and the 81 KZ1000J1, so I don't know if they will interchange (I don't know what's different).
Post edited by: steell, at: 2006/12/28 10:27
- kzwolfsr
Re: 1981KZ 1000
01 Jan 2007 21:04
Hey Steell I need your advice in the same area. I just got my new bike the other day, almost the same model but I think k1. I tried starting it today and it sounds like only one spark plug was sparking or sometimes I wouldn't get any spark. What would be the resistance value from wire to wire on the coils, secondary resistance? I posted a post about this but no one is answering. Please give me some insight. Also where did you get such clear pictures?
Post edited by: kzwolfsr, at: 2007/01/02 00:05
Original man of the Caribbean
- steell
Re: 1981KZ 1000
01 Jan 2007 21:51
Pictures are from the parts diagrams at
Kawasaki.com
I'll look at your other thread again now that I know what bike you are having problems with
- pumps
Re: 1981KZ 1000
02 Jan 2007 03:19
kzwolfsr..do you have the wiring diagram ..or will that even help? It is in the filebase here on the site.
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
1977 Yamaha XS650
2000 Kaw W650
- kzwolfsr
Re: 1981KZ 1000
02 Jan 2007 05:38
I didnt no yall had a diagram on here too. I will check it out
