1980 KZ750 LTD Starter Switch
- jcogdill
26 Dec 2006 14:32
I am in need of a starter switch and I am having trouble finding a source. Kawasaki no longer makes them. Anyone have any suggestions? Thanks,
- Bluemeanie
Re: 1980 KZ750 LTD Starter Switch
26 Dec 2006 19:00
Try here... I believe 650 and 750 are the same...
Bluemeanie's Link
Post edited by: Bluemeanie, at: 2006/12/26 22:02
Post edited by: wiredgeorge, at: 2006/12/27 09:47
///bluemeanie! - Look at the format of the redone link that Loudvhx posted and use it the next time or just the auction number. Thanks! wg moderator///
Post edited by: wiredgeorge, at: 2006/12/27 09:49
- loudhvx
26 Dec 2006 22:38
Bluemeanie's Link
PS, if you use the "quote" option on my post, you can copy the link code and paste into your post. Using the URL link code will make the page load properly.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Nevco48
27 Dec 2006 05:15
jcogdill wrote:
Ebay is one option, particularly if you arent going to be riding all winter and have time to search for one. Whereabouts do you live? You could post a "Wanted" ad in the KZR classifieds here too.
What is wrong with the button? Some guys here have had good luck getting inside the handlebar controls and fixing a broken switch or wire. It doesn't cost anything to look....
- wiredgeorge
27 Dec 2006 06:51
jcodgill, Are you talking about the button up on the right hand switchgear or the starter solenoid located down near the battery box on your bike?
- jcogdill
27 Dec 2006 16:47
This is the right side handlebar kill switch and start button. I recently purchased the bike and the previous owner tried to fix the button. I was blowing a fuse each time I turn the ignition on. I disconnected the switch lead and the dash lights come on. There appears to be a short isolated in the switch. Maybe there is an electrical shop that can redo it. I can't find a switch anywhere. I looked on ebay and do not see one at this time. Will keep trying. In the mean time I am polishing and cleaning.
- apeman
27 Dec 2006 17:31
I see these on eBay all the time. They are most often listed as "handlebar controls", or something of that nature. I believe the right side switches are the same for all 1980-82 KZ650, 750, and 1000. Also, other years often will work. The ones in the listed year range should be a straight bolt on and plug in.
It is easy to disassemble the switch, then take it apart and clean and lube the contacts. Also, make sure you insulate any internal contacts from the handlebars (use tape, or liquid rubber).
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
- jcogdill
28 Dec 2006 20:11
Thanks for everyone's help. I located the part I need and it has been shipped.
