KZ650B Carb Sync - How?
  • Skyman
  • Skyman's Avatar
Re: KZ650B Carb Sync - How?
29 Nov 2006 09:37
#95970
For you guys who have made your own test guage rig, what did you use for restrictors, and where did you get them?
Thanks.
Post edited by: Skyman, at: 2006/11/29 13:11
West Linn, OR
  • loudhvx
  • loudhvx's Avatar
29 Nov 2006 23:35
#96167
The restrictors can just be a top from a pen with a pinhole in it. Basically anything that will fit inside the tubing that you can poke a pinhole into will work. The restrictor should be as near the carb ports as possible so the tubing will not affect the reading.
  • sbjones
  • sbjones's Avatar
30 Nov 2006 01:30
#96171
is there a spec to start at. on my carbs all of the lock nuts were loose and backed out when i got into them.
i was told ones that there really is not starting point, or spec on carb synching, is this correct!?
  • JMKZHI
  • JMKZHI's Avatar
Re: .
30 Nov 2006 05:02 - 03 Dec 2008 14:03
#96186
del
Last edit: 03 Dec 2008 14:03 by JMKZHI.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
30 Nov 2006 05:07 - 03 Dec 2008 14:04
#96187
del
Last edit: 03 Dec 2008 14:04 by JMKZHI.
