- Thank you received: 512
Way to keep airbox?
- baldy110
03 Oct 2019 18:27 #811734
by baldy110
Replied by baldy110 on topic Way to keep airbox?
I would keep the Vm26's.
The following user(s) said Thank You: Patton
- Thank you received: 1656
04 Oct 2019 05:33 - 04 Oct 2019 05:34 #811760
by martin_csr
Replied by martin_csr on topic Way to keep airbox?
If wiredgeorge didn't figure it out, then there probably isn't a simple solution. He's been doing carb work for years. still does.
The 79 airbox ducts are longer than the 81-on ducts and the airbox holes are probably different diameters. From the diagrams at partzilla the frames, airboxes & battery case stuff are different, so the airboxes probably don't swap >> even if they did, there's still the problem of the distance between the airbox & carbs which I would assume is greater on the 79 because of the longer ducts. On some models when the stock ducts are NLA, some guys have no choice but fab ducts from radiator hose or rubber plumbing fittings or something, so this may be your only solution to keep the airbox.
Last edit: 04 Oct 2019 05:34 by martin_csr.
