VM 26 ss overflowing
- The Fish
Re: VM 26 ss overflowing
06 Sep 2006 05:48
Let us know how it turns out. It is possible that you only had 1 sticking float and that the fuel running out of the 1 tube got over the other 3 overflow tubes making it look like all 4 were leaking.
While the carbs are off, remove all the jets and make sure that they are all clean and make sure that the bowl vents are clear.
Good luck!!
Fish
Good luck!!
Fish
- Rickman
06 Sep 2006 08:15
antokan12 wrote:
damn, you're lucky enough just to be able to clean your carbs at work.. and people think the Interweb is the biggest loss of productivity... Oh Shi#, gotta go...Cleaned everything with Kraft spray and blow the holes with an air can for PC's (I do not have a compressor available at work)
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
- antokan12
06 Sep 2006 13:09
And I am not even a mechanic! :laugh: If I was I would probably be cutting someones hair in the backroom or painting my nails or whatever else which is NOT related to my job. Spain is different. Well, back to the subject soon when I install the carbs again (this time not at work)
