carb identification
- bharper6649
carb identification
26 Aug 2006 05:10
After doing a little work I've come to the conclusion that My bike is a mut. I think I have parts from 73, 74, and 75 Z1s. Not to mention the 78 front end I put on it. Anyway I have had a lot of problems getting the carbs tuned and want to make sure I using the correct specs. Can anyone tell me what carbs I have based on these pictures or tell me how.
Post edited by: bharper6649, at: 2006/08/26 08:14
Post edited by: bharper6649, at: 2006/09/20 18:05
1974 Z1 900
4-2 Exhaust, Pods
Dyna Ignition and Coils
WG Coil Mod
4-2 Exhaust, Pods
WG Coil Mod
- The Gringo
- ¡Usted no necesita otra motocicleta!
Re: carb identification
26 Aug 2006 05:43
Your carbs appear to be Mikuni 28 mm carbs that were used on the Z-1 from 72 to 75. In 76 they went to 26mm carbs for the KZ900
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- bharper6649
26 Aug 2006 06:25
Any suggestions on jets? Currently I have 115 mains and 20 pilots. I didn't put these in, so I'm not sure of the logic behind the combination. The bike has pods and 4 into 2 exhaust that is pretty open(very little baffle). I raised the needle to keep from fouling plugs, but really want to get it setup correctly. Any help would be appreciated.
1974 Z1 900
4-2 Exhaust, Pods
WG Coil Mod
4-2 Exhaust, Pods
WG Coil Mod
- wiredgeorge
26 Aug 2006 07:36
75 Z1B VM28SC: rejet to #120, #17.5 5J9-3 - Please limit the number of pics in a post as I never was able to sit still long enough for more than one to fully load. Some of us are on dial up connections! Thanks wg
- bharper6649
26 Aug 2006 07:44
Sorry about the pics. I've been on broadband so long I never consider speed. I will keep the pics to a minimum in the future. I'm off to buy some jets.
Thanks.
Thanks.
1974 Z1 900
4-2 Exhaust, Pods
WG Coil Mod
4-2 Exhaust, Pods
WG Coil Mod
- wiredgeorge
26 Aug 2006 07:53
Not a problem... when I download pics, it occurs at 3KBS... posts with LARGE or many small pics are painful.
BTW: The pilot jets on your carbs are the same as on the later VM series carbs and not the same style as the 73/74 pilot jets. Your #20 pilots probably won't hurt but you had best have a good spark or your plugs will soot.
- bharper6649
28 Aug 2006 07:33
The main jet switch helped a lot. I'm still trying to track down the smaller pilots. Maybe I can get this thing screaming before winter.
Thanks for all the help!
1974 Z1 900
4-2 Exhaust, Pods
WG Coil Mod
4-2 Exhaust, Pods
WG Coil Mod
- bharper6649
20 Sep 2006 15:03
wiredgeorge wrote:
George,
After talking with Jeff from Z1 enterprises we figured out I have the older model carbs. Does your recomendation change for the older carbs?
Thanks
Bryan
George,
Thanks
Bryan
1974 Z1 900
4-2 Exhaust, Pods
WG Coil Mod
4-2 Exhaust, Pods
WG Coil Mod
- Jeff.Saunders
20 Sep 2006 18:00
Hello Bryan, I'm very confused with your carbs. The pilot jets you showed in the picture to me are the early style with just 6 bleed holes - yet your carbs are the later Z1 carbs...
Not sure what to think.
- wiredgeorge
22 Sep 2006 08:26
The carbs pictured appear to be Z1B carbs (1975). To verify, there is an ID mark inside the red circle on the flange.
2170=1975
1473=1974
1470=1973
The bowls are totally different and not interchangeable from the 75 to the earlier models so I think you will see a 2170 ID mark.
The stock pilot jets on EITHER the earlier Z1/Z1A carbs or the later Z1B carbs will accomodate the use of pods and aftermarket pipes as they are relatively rich when added to the relatively rich jet needles/needle jets used in those carburetors. In other words, if you have the stock (#20 on the Z1/Z1A) or #17.5 on the Z1B variation, it doesn't matter much... you will be OK... Note that I suggested reclipping to the 3rd slot on the jet needles if you have the Z1B carbs.
2170=1975
1473=1974
1470=1973
- bharper6649
24 Sep 2006 19:04
Jeff.Saunders wrote:
I'm confused as well. The more I work on the bike the more confused I get. I have parts from at least 3 different years. Its no wonder I cant get it running just right. As for the carbs I can't find the ID George mentioned. I can't be sure I'm looking in the right place. Can you point me in the right direction?
1974 Z1 900
4-2 Exhaust, Pods
WG Coil Mod
4-2 Exhaust, Pods
WG Coil Mod
- wiredgeorge
25 Sep 2006 05:57
It is a small marking on the carb flange where it enters the bracket that holds the four carburetors.
