Way rich with stock jets
  • high toned son of a bitch
  • high toned son of a bitch's Avatar Topic Author
Re: Way rich with stock jets
29 Aug 2006 19:16
#73320
OK, got the jets out. The 76 carbs (which is what is on it now) have the following:
115
17.5
the 79 accelerator pump carbs have the following:
110
15
The larger numbers were on the end of the big jet in the center where the needle goes down into. I have not seen where the "clip" is located on the needle either.
The smaller numbers are on the side of a little jet beside the bigger center jet.
Sorry, I don't know which ones are which. I am a dummy when it comes to carbs.
31 Aug 2006 08:56
#73638
Should there be o-rings on the Main Jet's?
Thanks
  • wiredgeorge
  • wiredgeorge's Avatar
31 Aug 2006 11:33
#73686
The 76 KZ900 VM26s didn't have orings on the main jet holder tubes (emulsion tubes) as I recall.
31 Aug 2006 12:20
#73692
I saw that the throttle range where I am having the problem involves the "needle jet, pilot jet, and pilot tube". How can I check those things, or should I change the needle height?
Thanks,
31 Aug 2006 13:37
#73701
My carbs are mikuni and the O.D. of the inlet is 1.340" which convertes to 34mm.
If this helps anything
  • Rickman
  • Rickman's Avatar
19 Sep 2006 11:21
#77853
I'm still liking the plugs are too cold suggestion. is B7ES really stock for that bike? Mine's B8ES.
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
