How do you \"clean a carb\"?
- Jerka
Re: How do you
16 Aug 2006 13:43
Would it hurt to run sea foam and some carb cleaner? I am a fan of the sea foam...I use it in my Jeep Cherokee, but through the throttle body not in the gas.
- OKC_Kent
Re: How do you
16 Aug 2006 13:51
Jerka wrote:
Probably won't hurt it a bit. The seafoam can has directions for mixing with fuel. like 1 oz to 1 gallon gas.
I would change the oil as the first thing. See z1Enterprises for the filter, you can have it in a few days.
Cashion, OK
78 KZ650 B2 85,000+ miles
- Jackman
Re: How do you
17 Aug 2006 05:06
www.allexperts.com/browse.cgi?catLvl=3&catID=837
Here's a site i use now and then. These guys have answered alot of my questions. Hope it helps. I talk to Mike Shively the most
Post edited by: Jackman, at: 2006/08/17 08:20
- ran429
- Master of FREE rides!
Re: How do you
18 Aug 2006 12:42
i would pull the carbs, flip them over, drop the bowls in carb cleaner, unscrew the jets, take the top off of each carb, clean the diaphrams & needle, soak caps in cleaner, toss screws in cleaner, soak all brass jets for 15 minutes scrub & repeat with soft tack cloth or something unabrasive, blow all the ports holes and whatever else you can think of with compressed air (in a can if you dont have a compressor) and wipe everything down making sure all the jets are see through in the little holes.
let parts dry, lubricate anything you think needs it and reassemble.
Doing ONE carb at a time is a benefit for someone that has never done it, this way you can look at the other one for a road map on where things go during reassembly.
Have fun and do this on Butcher paper and wear latex gloves.
- Robjb84
Re: How do you
19 Aug 2006 18:48
I was able to pick up the oil filter for my KZ440 from a local Napa, just for convenience sake.
- Jackman
Re: How do you
21 Aug 2006 07:48
Jerka If you going to run the carb and combustion chamber cleaner through it with it running change the oil AFTER not before doing this it picks up alot of carbon.
- duncan
Re: How do you clean the carbs
01 Dec 2006 14:17
Jackman wrote:
just found this carb cleaning 101 by mike shively:
experts.about.com/q/Motorcycle-Repair-837/1978-KZ650-carb.htm
Post edited by: duncan, at: 2006/12/01 17:20
www.allexperts.com/browse.cgi?catLvl=3&catID=837 Here's a site i use now and then. These guys have answered alot of my questions. Hope it helps. I talk to Mike Shively the most
