Expanding O-Rings
- Duck
- e vica na i sau na ga
Re: Expanding O-Rings
11 Nov 2005 16:08
I used to buy O-ring material from Ga Rubber and cut to size
You cut it on the bias, about 60 degrees to the axis, and use super glue. They kit companies are selling O-rings made of the wrong material if it's expanding. I've seen the same thing with float valve O-rings if I don't specify the right ind.
I'm gonna be doing some CB650 carbs early next month and appresiate the heads up on the problem. Will probably lok on www for source of fuels resistant material and make my own rings after reading this thread. Unless, the bowl edgesare falt enough, in wjich cace, I'll just whittle something out of the nitrile rubber gasket sheet material from the autoparts store.
Have a mess of it from other projects
Anybody got a decent CB650 gas tank cheap?
Mine is full of rust and giant flakes of some sort of misapplied polymer tank coating crap.
Hope to get CB650 in decent shape for winter solstice gift to my brother.
-Duck
-Duck
- nads.com
11 Nov 2005 18:29
my last bike was real fast, ran greaat. Then i freezer burned the damn o rings......com onnnn.
- KZQ
- Administrator
11 Nov 2005 18:50
There's a wide variety of qualities of "O" rings on the market. A bunch are trash from China. Basically look for some assurance that they are neoprene not rubber. Look for a manufacturer that has any status or at least an address. As for using gasket sealant on a carb float bowl, Bad JuJu! if the O ring's not sealing solve the real problem. Don't goop it up with something that you'll have to clean up later.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- Shoey949
11 Nov 2005 19:06
well the theory of the float level being off has been quickly shot down. I measured and they are right on spot. What could be causing the gas in the oil then? Duck would should I look for as far as gasket material and where can I get it and can a use just a utility knife?
Thanks,
Nate
Thanks,
Nate
'83 GPz550H2 w/'81 GPz 550D1 engine
Dynojet Stage 3 kit, MAC 4-1, UNI Pods, DYNA coils and plug wires, WG ignition mod
Grand Rapids, MI
Grand Rapids, MI
- ibsen22000
12 Nov 2005 05:30
KZCSI wrote:
You don't goop up anything as long as you just put a small streak in the bottom of the groove before you put in the o-ring. I don't use it to make a seal, but to keep the o-ring in the groove. And it's much easier to remove than superglue.:whistle:
KZCSI
- oldcoldankles
12 Nov 2005 06:25
When you encounter an O-ring problem like this try to get Viton O-ring material instead on Buna N - it is a much better quality material.
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
1981 KZ1000 CSR M1
1989 Corvette coupe
- Shoey949
15 Nov 2005 16:49
I'm sorry I 'm just getting really desperate at this point. I have a question though how does fuel get that high anyway? Is the float and needle supposed to stop that anyway? BTW I have cleaned the carbs, replaced the float needles and the floats have no cracks. Also do you think K&L Carb gaskets would solve my problem/be better than keyster?
Thanks,
Nate
Thanks,
Nate
Grand Rapids, MI
Grand Rapids, MI
