Vm Cutaway modif?
  • Maxbou92
  • Maxbou92's Avatar Topic Author
Vm Cutaway modif?
25 Aug 2026 08:02
#926992
    Hello, I drilled my air corrector to 0.6 instead of 0.5 and nothing change about my Rich cruising.. but half and wot is lean now.. grrr.
im planning to modify my Cutaway with the machinist over there.. what is the angle he needs to cut? And how many material needs to be remove? Thank you very much
Kz750e 1980
  • zed1015
  • zed1015's Avatar
Re: Vm Cutaway modif?
25 Aug 2026 09:07 - 25 Aug 2026 11:34
#926993
The cutaway number (ie. your #1.75 etc) is not a measurement in mm
The number comes from the Amal method of identifying the size of the cutaway.
Each whole number on a Mikuni round slide carb represents 1/16" of cutaway from the bottom of the slide to the top of the cutaway.
Each .5 is an additional 1/32" and each 0.25 is an additional 1/64" .
1.0 cutaway = 1/16"
2.0 cutaway = 2/16"
2.5 cutaway = 5/32"
3.0 cutaway = 3/16"
3.5 cutaway = 7/32"
If machining the cutaway do not move the point where the cutaway meets the bottom edge like you have marked on the slide in the pic.
You should start by increasing the cutaway to a 2.0 = 2/16" (3.175mm ) at it's highest point.
Last edit: 25 Aug 2026 11:34 by zed1015.
The following user(s) said Thank You: slmjim+Z1BEBE
  • Maxbou92
25 Aug 2026 09:15
#926994
Ok!! So whats mine? 2.0 ?
Kz750e 1980
  • Maxbou92
25 Aug 2026 09:23
#926995
I dont really understand where I need to cut them. +0.5mm on the center to the corner? I need to keep the corner intact and remove materials in center?
Kz750e 1980
  • zed1015
  • zed1015's Avatar
25 Aug 2026 10:55 - 25 Aug 2026 11:06
#927000
Your slides are currently a 1.75 cutaway so the next stock size would be 2.0.
The arc of the cutaway should be lifted by 1/64" ( 0.4mm max to make it simpler ) at the highest centre point and tapered back in a smooth curve to zero at the corner where the current arc begins.
Last edit: 25 Aug 2026 11:06 by zed1015.
  • Maxbou92
25 Aug 2026 11:03
#927001
Thank you, I just measured them and on the table up to arc I get 0.130 “ (1/8-3.3mm) !! Weird that it mentions 1.75 in it
Kz750e 1980
  • Maxbou92
25 Aug 2026 11:03
#927002
Would you go to 0.8mm one step?! Dont want to go at the shop 3-4 times!!
Kz750e 1980
  • zed1015
  • zed1015's Avatar
25 Aug 2026 11:43 - 25 Aug 2026 11:44
#927005
You should really go 1/64" (0.4mm) at a time.
It's not easy to add material back on if you go too far..
Last edit: 25 Aug 2026 11:44 by zed1015.
The following user(s) said Thank You: Maxbou92
  • Maxbou92
25 Aug 2026 12:18
#927007
If you remember my cruising is 10.5-11afr. You think 0.4 will make a noticeable difference?
Kz750e 1980
  • zed1015
  • zed1015's Avatar
25 Aug 2026 14:28
#927009
The slide cutaway mainly affects 1/8 to to 1/4 throttle so small changes to the cutaway height will make the most difference in this area.
Whether an initial 0.4mm lift will give the required result won't be known until it is tried.
  • Maxbou92
25 Aug 2026 15:13
#927011
Zed, Do you think thats risky to ruin my slide if the machinist do it ?! 0.4mm from center to the corner..
Kz750e 1980
  • zed1015
  • zed1015's Avatar
26 Aug 2026 04:16
#927023
Ideally you would have another set of slides to experiment on.
As long as you can get all the cutaways the same i would modify the slides myself with a half round needle file given the small amount that needs removing at each stage.
The following user(s) said Thank You: Wookie58, Maxbou92
