KZ550 F2 Carb Holder O ring alternatives/dimensions
- SirCanucklehead
08 Aug 2024 08:50 - 08 Aug 2024 08:51
Finally got my project 550 running after a couple years. Turned out to have a nasty vacuum leak though, and I'm pretty sure I narrowed it down to the carburetor holders on the head.
I managed to get some new holders, but I'm having real trouble finding o-rings for them (part number is 92055-1233). Does anyone know of a drop in alternative that would work, I've got a kit of numerous sizes of o-rings but the trouble is, the rubber itself is far too thick for the holders to be able to compress the ring and seat flat against the head. So ideally, I would like to know the thickness of these parts when fresh (my old ones are completely disintegrated so I can't go off them).
If anyone has any insight I'd greatly appreciate it.
1984 KZ550 LTD Shaft
Last edit: 08 Aug 2024 08:51 by SirCanucklehead. Reason: formatting
- gd4now
- Denco where did you go?
Re: KZ550 F2 Carb Holder O ring alternatives/dimensions
08 Aug 2024 09:29
Partizilla indicates they have that part (92055-1233) Can not say if they do or not, as I did not try to purchase any.
www.partzilla.com/product/kawasaki/92055...1b97db74de383b49cb87
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
08 Aug 2024 11:35
Viton O-rings are needed for that application. Common Nitrile will quickly fail due to the heat.
You might want to try measuring the groove in the boot. O-rings are commonly sized by thickness and ID. A dash number sized O-ring may fit. You can find conversion charts for the size. If you measure the groove, I can help you look...
- SirCanucklehead
09 Aug 2024 04:09
@gd4now unfortunately, they're on backorder with no ETA at partzilla. Needing to cancel my order is what brought me here.
@Nessism i will get a quick measurement of the O-ring groove on the holders today after work and get back to you.
- Bloobaba
09 Aug 2024 06:55
Good morning. apparently available here.
kawasakioriginalparts.com/products/920551233
And here.
www.cmsnl.com/products/ring-o-carburetor-hol_920551233/
a little expensive for 4 O-rings but at least you will have peace of mind.
And here.
Z400F 84 (ZR400B1)
Gpz900R 84
500 H1 73
Gpz550H1
Gpz900R 84
500 H1 73
Gpz550H1
- SirCanucklehead
09 Aug 2024 13:32CMSNL is great, they've saved my skin a couple times with hard to find parts (pretty sure I snagged the last new center stand main spring on the planet there), but shipping is not the cheapest. It'd work out to almost $100CAD just for 4 o-rings. You're right, peace of mind and all, but if I can spend less and get decent quality generic replacements locally, or at least shipped from within North America, I'll happily take that.Good morning. apparently available here.
And here.
- SirCanucklehead
09 Aug 2024 13:44 - 09 Aug 2024 14:07So, I just measured the groove on my replacements. They're just a hair above 1/16 of an inch wide (no metric tape or ruler lying around sadly). 1 and 11/32 inches is the diameter of the groove, so that translates to (roughly) 1.6mm cross section and 34mm diameter.Viton O-rings are needed for that application. Common Nitrile will quickly fail due to the heat.
Edit, I should add, that diameter is center to center, so the outer diameter is more like 1 and 13/32, and the inner diameter is more like 1 and 5/16
Last edit: 09 Aug 2024 14:07 by SirCanucklehead.
09 Aug 2024 14:56More exacting size info is needed to be sure. Get some calipers and measure again.So, I just measured the groove on my replacements. They're just a hair above 1/16 of an inch wide (no metric tape or ruler lying around sadly). 1 and 11/32 inches is the diameter of the groove, so that translates to (roughly) 1.6mm cross section and 34mm diameter.Viton O-rings are needed for that application. Common Nitrile will quickly fail due to the heat.
Based on the info stated, the closest I can find is a Dash 027 Viton O-ring.
www.mcmaster.com/9464K271/
- SirCanucklehead
09 Aug 2024 15:19Unfortunately I don't have any calipers handy. I may have access to some this weekend at some point, if so I will report back.More exacting size info is needed to be sure. Get some calipers and measure again.So, I just measured the groove on my replacements. They're just a hair above 1/16 of an inch wide (no metric tape or ruler lying around sadly). 1 and 11/32 inches is the diameter of the groove, so that translates to (roughly) 1.6mm cross section and 34mm diameter.Viton O-rings are needed for that application. Common Nitrile will quickly fail due to the heat.
- Bloobaba
10 Aug 2024 02:58
No eBay APP ID and/or Cert ID defined in Kunena configurationHere.
You buy one and take the dimensions. thus, no possible error and no hole in the pistons 😄
Z400F 84 (ZR400B1)
Gpz900R 84
500 H1 73
Gpz550H1
Gpz900R 84
500 H1 73
Gpz550H1
- SirCanucklehead
17 Aug 2024 05:02Sorry for the late reply. Last weekend turned out busier than I thought, then I was away for work all week. I got some calipers though, and some precise dimensions.More exacting size info is needed to be sure. Get some calipers and measure again.So, I just measured the groove on my replacements. They're just a hair above 1/16 of an inch wide (no metric tape or ruler lying around sadly). 1 and 11/32 inches is the diameter of the groove, so that translates to (roughly) 1.6mm cross section and 34mm diameter.Viton O-rings are needed for that application. Common Nitrile will quickly fail due to the heat.
Outer diameter: 36mm
Inner diameter: 32mm
Groove width: 1.8mm
Hopefully these will do, I appreciate your helping out.
17 Aug 2024 06:07
That dash 027 Viton is pretty close. No guarantee, though.
