Sticky fluid
  • Andyp62
  • Andyp62's Avatar Topic Author
Re: Sticky fluid
12 Mar 2024 01:40
#896309
I had to use an impact screwdriver, will be replacing them with new ones
1978 Z650 B2, US import to the UK
  • asphalt900
  • asphalt900's Avatar
Re: Sticky fluid
12 Mar 2024 03:24
#896312
Like Warren mentioned, i've seen similar when the lined "red-coat" tank material breaks down but you say it's not. You might drain the tank and have a peek down at the very back and bottom, where the petcock is. Or even pull the petcock and have a look-see. Someone could of in the past "tried" to of sealed or of removed a former coating and left behind crap at the bottom. Do you still have the pleated paper air filter or an over-oiled K&N? That certainly is a mess!
The following user(s) said Thank You: Andyp62
  • Andyp62
Re: Sticky fluid
13 Mar 2024 01:13
#896353
I will have a better look in the tank to see if I have missed something, and remove the e tap, it has the standard paper air filter set up,
thanks
